Old 06-05-2010, 05:33 PM   #15
1960 24' Tradewind
Riverside , California
Here's 2 shots of the cork floor in my '60......Dare to be different!
Greg
ID:	104098   Click image for larger version
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 06-06-2010, 12:17 AM   #16
wanderluster
Ophir's Avatar
2005 28' International CCD
Salt Lake City , Utah
WOW!!! Nice job. That is so great.
Ophir is offline   Reply With Quote
Old 06-06-2010, 07:46 AM   #17
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
Great job on the floors guys, that is my next project!
Happy Trails!
Jezibels is offline   Reply With Quote
Old 06-06-2010, 09:16 AM   #18
LuvRVing's Avatar
1995 31' Land Yacht
Clovis , California
Ophir, where did you buy your tiles and what worked best for cutting them?
TAC: CA-3
LuvRVing is offline   Reply With Quote
Old 06-06-2010, 10:25 AM   #19
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Love that Cork! Cork Flooring - 1956 Vintage Airstream
1956Safari is offline   Reply With Quote
Old 06-06-2010, 11:17 PM   #20
wanderluster
Ophir's Avatar
TAC: CA-3
I them from the Green Building Center in SLC (Eco Friendly Building Materials and Flooring - The Green Building Center)
I got the tiles so I could glue and went with the "Natural Bamboo" from Vida. You can cut them with a razor but looking back I would have loved to have had a razor that I could use in a jig or a device that would hold the tile and cut square, like those things that you use for cutting matting for framing photos. We just used razors and squares. It's pretty easy, just really laborious.
Old 06-07-2010, 12:51 PM   #21
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
As promised...
I have taken photos of the finish up process....so far. I did not photo record the start of the cork plank floor installation in our '66 Trade Wind, 24'. The PO had installed the sticky back floor tiles and they were getting unsightly with the tiles shifting a little when warm and the glue creeping along the seams and attracting dirt. Fortunately the PO had removed the old original asbestos 'laced' tiles up to the cabinets. I began removing the sticky tiles with myself sticking to the residue left on the flooring. I researched online on how to remove the glue and became discouraged to the tedious job it would be. I then decided to leave the tiles but better judgement took over and removed these sticky tiles. The floor was so sticky it began removing my shoes as I stepped around. One of the reasons we opted for the 'floating' floor was to allow for expansion and flexing but laying the cork on this glue would not only defeat this but would have been a hullava job. I bought plastic moisture barrier material and laid that down first. That's the blue plastic in the photos. PERFECT solution!
The photo are some what self explanitory. However the do have to be installed left to right, back to front. So I had to start in the rear bath and lay one row then the next, etc. It takes time to cut around cabinets and so. The instuction say to leave a gap of up to 1/4" inch at cabinettes and such for expansion then instal a molding anchored to walls and cabinets leaving the flooring to 'move' under it. A contractor who has laid such flooring says he didn't think the 200 sq feet that I was cinstalling didn't require that much tolerance, so I haven't paid 'that' much to leaving that tolerances.
Neil.
ID:	104348   Click image for larger version
ID:	104350   Click image for larger version
ID:	104352   Click image for larger version
ID:	104354   Click image for larger version
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-07-2010, 12:52 PM   #22
FreshAir's Avatar
1966 24' Tradewind
More to come
Yeah, it's lunch time. I'll have more piccys of this install soon.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 06-07-2010, 01:55 PM   #23
FreshAir's Avatar
1966 24' Tradewind
'66 Trade Wind cork floor install continues
As mentioned I had not planned a photo documentary of this installation but several of you said that you would like my imput. The only install that I had left to do was at the entry. So these first few photos show the way this floor 'clips' together. Other than cutting around 'obstacles' it goes fairly easy. However, if you discover a boo boo a little back in your installation you have to undo your planks installed back to that repair.
The last 2 photos in this post show 1) the way I'm thinking of bordering the edges where I need to cover the gaps at the perimeter. I only placed the molding that you see as an example. What I will use is trim that I will shape myself and stain to match the wall molding and 'pocket' boxes above our beds...last photo.
A couple of more piccys to follow.
Neil
ID:	104356   Click image for larger version
ID:	104358   Click image for larger version
ID:	104360   Click image for larger version
ID:	104362   Click image for larger version
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 06-07-2010, 02:05 PM   #24
FreshAir's Avatar
1966 24' Tradewind
Well, I have only one piccy left and that comes with a request for guidance here. A molding over where the floor meets the tub has me be-fuddled. I can't use a wood curved one. One suggestion is a plyable caulking to fill this gap. But such caulk attracts and holds dirt. A thin bead of black caulk 'may' work. Waddyou think? I have a similar problem along the storage doors beneath the beds. The doors are hinged at the floor and negates the placement of a molding there. Any ideas.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 06-07-2010, 02:23 PM   #25
1986 25' Sovereign
Plant City , Florida
Neil.
My idea would be to purchase some corner round from lowes and nail it in place. You can get some that is made of plastic covered vinyl and use a saw to make relief cuts in the back so that it will bend around the tub.
As for the other situation I am not sure it will work but you could try a flooring transition. these are typically very thin and would cover the gap well.
ck21084 is offline   Reply With Quote
Old 06-07-2010, 02:48 PM   #26
FreshAir's Avatar
1966 24' Tradewind
Thanks, I know what you are talking about. Any trim around the tub would have to be afixed to the tub not the floor. I could probably screw or rivet the trim to the 'plastic' tub. I am going to Home Depot tomorrow and will check it out.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 06-08-2010, 08:06 AM   #27
stephenh2's Avatar
Tyler , Texas
There are trims available that are very flexible. I have seen some in a house that ha about a four foot diameter circle in the ceiling that was completely trimmed out in the stuff. We're talking some 6" crown moulding formed into a circle. It is like a flexible foam type plastic with a finished surface. I haven't seen any of it in the big home centers, but Google resulted in good results.
Stephen
Home again in Tyler, Texas
Please visit any time!
stephenh2 is offline   Reply With Quote
Old 06-08-2010, 04:27 PM   #28
FreshAir's Avatar
1966 24' Tradewind
Stephen
Just returned from Home Depot. Yur right, they aren't that specialized. We just had all the windows in our home replaced. They used plastic trim for the finish. Looks good. I wished I had paid better attention during the installation and asked some questions. Next trip down the hill to Sacramento I will check with finish carpentry suppliers. Thanks for the tip.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Cork flooring pictures please bertro Floor Finishes 16 05-05-2010 08:48 PM
Cork flooring question guy99 Repairing/Replacing Floor &/or Frame 19 12-02-2006 03:24 PM
Best Way to Install Cork Flooring? highmark Floor Finishes 9 08-23-2006 08:41 AM
OSB For Cork Looking Flooring topazken Repairing/Replacing Floor &/or Frame 8 10-16-2005 04:38 PM
Cork flooring ALANSD Upholstery, Blinds, Walls & Interior Finishes 5 01-14-2004 07:14 PM
