05-10-2010, 07:19 AM
1966 24' Tradewind
Placerville
Cork floor in the bathroom
I am about to install cork flooring in our '66 Trade Wind. Would it be risky to put it down in the rear bath or should I consider another flooring just in there that is resistant to water damage from using the shower?
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
05-10-2010, 07:33 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Shouldn't be a problem unless you anticipate standing water on the floor. Cork is naturally mildew & mold resistant - so as long as you don't have unattended puddles left after a shower you should be fine. Also, try to avoid tiles with a "fiberboard" style backing...it may absorb water & swell. As an extra precaution, I would caulk the perimeter so water doesn't get underneath and effect the plywood subfloor - but that's the case with any product in wet areas like bathrooms.
Shari
05-10-2010, 07:44 AM
Oak Cliff
click together floors are damaged easily by water getting underneath, many cork floors are the click type
05-10-2010, 07:55 AM
2007 25' Safari FB SE
Eureka Springs
, Arkansas
I asked my flooring supplier about cork tile for our coach.
He rec'd against it as he has had problems in bathroom and kitchens.
I'm not sure of which type of flooring it was. We decided to go with vinyl tile.
I wanted sheet vinyl, but for it to be seamless, one has to buy 12' wide material which results in a lot of waste.
05-10-2010, 08:43 AM
Las Vegas
, Nevada
Don't mean to get off subject but just had to say we really like Ian's avatar.
05-10-2010, 08:48 AM
1966 24' Tradewind
Placerville
Shari
Shari, good point on caulking the perimeter. I am using the plank cork and will put down a poly sheeting under it. Still I was/am concerned about inevitable spilled water creeping between the poly and the bottom of the cork. Caulking all the perimeter throughout. Caulk 'shouldn't' negate the floating advantage. Any arguments to that theory?
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
05-10-2010, 08:56 AM
1956 22' Safari
Conifer/Evergreen
Depends on how flexible the caulk is - if it shrinks or hardens & cracks it wouldn't do the job. If it were me, I would not use the floating plank install in a bathroom area. It's a small enough area that it wouldn't need room to "float" IMO. But I guess if that's what you're going with throughout...just be sure you use a very viscous caulk that doesn't shrink or crack.
We glued down our sheet Marmoleum floors wall-to-wall in both our trailers and have had ZERO problems since 2002 and many 1000's of miles. I'm not "sold" on the floating floor concept except for plank-style floors or sheet vinyl which doesn't breathe like Marmoleum or cork.
Shari
05-10-2010, 09:00 AM
1966 24' Tradewind
Placerville
Thanks. His mom, our daughter, commented that the previous 'Happy Camper' avatar starring Ian's younger brother needed a follow-up with Ian. His drawing immediately came to mind.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
