Old 07-17-2010, 09:36 AM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Cork floor in sheet vs. tile? Is it available?
I like the idea of cork, but I don't like the idea of tiles. Can this be purchased and installed as a single sheet?
adwriter73 is offline   Reply With Quote
Old 07-17-2010, 09:45 AM   #2
Sheet floor coverings are not a good idea.
In time, they will crack at every 4 feet, because of the seams that are in the floor.
Those seams move when the trailer is in motion.
You can use tiles, and space them so that the seams match the floor seams.
Old 07-17-2010, 10:04 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Found a couple of threads for you to look at.
http://www.airforums.com/forums/f461...tos-65213.html
http://www.airforums.com/forums/f461...ase-61373.html
If you don't get a good consensuses on sheet vs tile you might what to send uwe a PM and get his thoughts.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 07-17-2010, 10:18 AM   #4
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Central , Illinois
tiles
I just completed a cork tile intallation in my trailer. It was easy to do a section at a time using waterbased contact cement. I started in the center of the floor and worked my way out to the edges.
Whether you use tile or sheet flooring, you are going to have to trim it to fit along the walls and built-ins. With tile, you only have to trim 12" at a time and can get a close fit. I cannot imagine trying to do that with sheet goods.
You might want to ask your flooring supplier what they recommend for adhesive with the sheetgoods and which system they would think easier for a DIY to tackle.
maccamper is offline   Reply With Quote
Old 07-17-2010, 11:49 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
My wife wanted cork, I like the idea of sheet vinyl. We found a super looking sheet vinyl in a commercial grade with a cork finish. I had the trailer gutted so instillation was easy. At the recommendation of TomW, who installed sheet vinyl in his Overlander several years ago and has had no problems, i only glued it down around the perimeter. This made it in effect a floating floor. We are very happy with the look.
Old 07-18-2010, 08:36 AM   #6
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Thanks for all the advice. One other question...
My Airstream is fully gutted, so I want to lay a think layer of luan plywood over the subfloor to get a clean, flat surface to apply the cork to. Do I need to match that plywood with the subfloor seams? Or should I overlap and offset it? My though is if I overlap, that it might strength the floor and be less prone to flexing at the seams.
Cork floor in the bathroom FreshAir Floor Finishes 7 05-10-2010 09:00 AM
sheet vs tile linoleum slimitch Floor Finishes 25 11-20-2008 08:07 PM
Cork floor Pahaska Floor Finishes 73 07-24-2008 01:46 PM
Marmoleum Flooring -Sheet or tile njunear Floor Finishes 6 04-22-2008 11:26 PM
Cork floor Charcigar Repairing/Replacing Floor &/or Frame 42 03-02-2006 01:25 PM
