Old 08-21-2003, 09:36 AM   #29
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Here's the opened package of cork. Great patterning with no two tiles the same.
Too bad that my trailer is at the dealer getting a new AC thermostat or I would be out there right no fitting tile.
John W. Irwin
WBCCI #9632
Old 08-21-2003, 09:54 AM   #30
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
like I mentioned in the other thread, I used 90lbs of pergo in my 23' trailer. it was $3 per foot. for such a small amount of sq. footage, the price difference is negligible. (I recently put in some $4/ft. pergo in my house...so it depends on the line you choose).
I saw a vintage globe-trotter at a recent rally that had a cork floor...I think he used a toung n groove type. He handed me a sample of it, and it seemed like a layer of cork on some sort of laminate backing. Anyway...it looked great! The stuff you got looks like very thin tiles..is that correct?
I'm surprised they used OSB for the subfloor. An architect friend of mine told me that you shouldn't use that stuff for underlayment, because the glue in it off-gasses. too bad for me; all the subfloors in my house are OSB.
Old 08-21-2003, 10:07 AM   #31
Pahaska's Avatar
Hays County , Texas
Yes, the tiles are about 1/4" thick. The glue-down isn't as thick as the T&G.
My information is that OSB uses the same glues as marine plywood which is used in most Airstreams. As far as I know, only the Internationals are floored with OSB. The floor is one piece. the lack of joints make the glue-down cork feasable.
John W. Irwin
WBCCI #9632
Old 08-21-2003, 11:11 AM   #32
hhuber's Avatar
Images: 8
Very nice cork flooring. Can't wait to see a photo of the installation.
Heidi
hhuber is offline   Reply With Quote
Old 08-21-2003, 03:07 PM   #33
87MH's Avatar
1978 31' Sovereign
Images: 292
"As far as I know, only the Internationals are floored with OSB"
I know of at least one '86/87 345 MH has the OSB underfloor.
I painted mine with "Kilz" prior to putting the Pergo down.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-26-2003, 01:03 PM   #34
Did you get the cork floor installed?
Clark
csimingt is offline   Reply With Quote
Old 08-26-2003, 02:51 PM   #35
Pahaska's Avatar
Hays County , Texas
Clark
Not yet. My trailer is sitting at the dealer waiting for a new thermostat for the AC. Hopefully, I will get it home tomorrow and can go to work on it. I'll post photos as soon as i can start working on it.
John W. Irwin
WBCCI #9632
Old 08-26-2003, 03:05 PM   #36
Pahaska's Avatar
Hays County , Texas
My layout
Here is my CAD layout of the floorplan with the 1'x2' cork tiles superimposed.
I chose to lay the tiles across the trailer because it is a lot easier to fit and trim the 1' edge than it is to work with the 2' length. Also, the waste is much less when laid crossways; I should have several full tiles left over to repair any future damage and a lot of partial tile pieces.
I have experimented and the tile edges are pretty much lost in the random pattern, so, while I am staggering the joints, I am making no attempt to line up all of the joints. I am doing this to reduce cutting and to retain some spare tiles.
John W. Irwin
WBCCI #9632
Old 08-28-2003, 06:41 PM   #37
Pahaska's Avatar
Hays County , Texas
Progress report
The trailer is back from the dealer with a new AC thermostat. I didn't get it home until about 6 PM, so I didn'taccomplish very much today.
The photo shows the first row of tiles in place and the contact cement spread for the full tile in the next row. The contact cement goes down green and when it turns clear, the tiles are ready to set. I thought I would do 2 rows at a time, but I have found that one row at a time works a lot better in the confines of the trailer.
John W. Irwin
WBCCI #9632
Old 08-28-2003, 06:48 PM   #38
Pahaska's Avatar
Hays County , Texas
First evening's work
I ran out of energy at this point. I make the major cuts with my bandsaw and the final trimming around the curves by hand. The contact cement really grabs, so it is impotrant to hit it right the first time. Tommorrow ought to pretty well finish putting down the cork. Then, I have to put in the black molding.
John W. Irwin
WBCCI #9632
Old 08-29-2003, 06:40 AM   #39
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Hurry up and get finished! I want to see what the final product looks like
Hmmmm I really like that. It looks great. Have to show the misses tonight and see what she thinks.
Once I get the floor straightned out I'll have to see if I can get it smooth enough to use that.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-29-2003, 08:44 AM   #40
cork
Looks very nice. You are convincing me to do this to my trailer (when I can find the time). Question, are you using any roller to press down the cork or just setting by hand? Also what is and where did you get the black trim?
Repodog is offline   Reply With Quote
Old 08-29-2003, 03:35 PM   #41
Pahaska's Avatar
Hays County , Texas
Almost done
Here is the rear of the floor with the black molding around the edges. I think it looks pretty fine.
I bought the molding from McMaster-Carr. It is a self-stick edge molding., rather pricy, but all I could find to use because of the curves in the furniture.. The cork is thinner than the carpet and pad, so the thin "L" of the molding goes under the furniture. Mcmaster-Carr has a number of different moldings.
I didn't roll the cork. I just did a dance on it. The adhesive really nails it down.
John W. Irwin
WBCCI #9632
Old 08-29-2003, 03:37 PM   #42
Pahaska's Avatar
Hays County , Texas
Sorry, forgot the photo
Guess I'm tired!
John W. Irwin
WBCCI #9632
Cork floor Charcigar Repairing/Replacing Floor &/or Frame 42 03-02-2006 01:25 PM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
repairing floor rot danesh Repairing/Replacing Floor &/or Frame 18 02-03-2004 09:34 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
