Old 06-12-2017, 12:07 PM   #15
Pleasant Plains , Arkansas
[QUOTE=Iansk;1962238]Not a dumb question, though perhaps a tad lazy.
The OP explains his underlayment decision in post #10.
Ignorance and lazy are two different things. I'm not an expert, not a carpenter, not a carpet installer. I'm on this forum to learn. Thanks for the help.
go_lope is offline   Reply With Quote
Old 06-12-2017, 12:29 PM   #16
1977 31' Sovereign
Sunset Valley , Texas
No offense meant...
[QUOTE=go_lope;1962254]
Honestly, I apologize if I offended you. My point was that your question was answered a few posts prior.
This is great and welcoming place to learn and share for sure.
When I put my new floating floor in my Silverstreak, I did opt for an underlayment. I feel it added some sound dampening as well as a bit more insulation, however nominal.
Iansk is offline   Reply With Quote
Old 06-14-2017, 06:36 PM   #17
[QUOTE=Iansk;1962266]
It's all good. I saw the above post so I maybe I didn't phrase my question right. When I say I'm new to this, I'm being literal in the sense that I don't know what the layers the floor consists of from the road up.
I wasn't sure if the subfloor was what I'd find under the carpet or existing floor. I'm so close to pulling the trigger on a 1973 Ambassador but I'm trying to do all the homework I possibly can in advance to avoid biting off more than I can chew.
Old 06-16-2017, 03:31 PM   #18
mariusg78's Avatar
1977 31' Sovereign
Covington , Washington
Images: 21
Hi everyone,
No, I did not put any underlayment down. It originally had shag carpeting without anything under it. I replaced the majority of subfloor with marine grade plywood to make sure it would never rot again. At least in my lifetime.
When I removed the damaged subfloor, there was insulation between the sub and frame. Bad idea with the moisture since it seemed to have trapped it and cause further damage. I did not put new insulation below either. I live in the Pac Northwest and it never gets cold enough to warrant insulation there. Anyway, I only use the trailer in the summer. The rest of the time it's stored and winterized.
I do have an issue with the flooring starting to gap in spots, but I have been able to put in stips to cover those gaps. With four kids and 2 dogs, it doesn't really matter to me that its not a show piece .
mariusg78 is offline   Reply With Quote
Old 06-17-2017, 10:15 AM   #19
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
Hi Mariusg78,
"With four kids and 2 dogs, it doesn't really matter to me that its not a show piece . "
Yeah!!! Love the attitude! I often wonder when reading the Forum is it the trailer or what the trailer allows you to do? I am in the latter catagory. Our Phoenix will never be a beauty, but she is always up for adventure!
Happy Travels with your Clan!
Susan
PS: your floor looks great!
duncans is offline   Reply With Quote
Old 10-02-2017, 02:17 PM   #20
rspect's Avatar
Theodore , AL
Originally Posted by mariusg78 View Post
I finished putting in new floors. Used Shaw vinyl plank flooring. This is the gunstock color. Easy to put in, just cut with a box cutter or blade and the pieces just snap right off. Lowe's also has this in stock, so any unused boxes are being returned for a refund. Yay!
You did a great job!
1973 Airstream Land Yacht Sovereign
rspect is offline   Reply With Quote
Laminate Flooring: which is best? perryg114 Floor Finishes 62 12-04-2012 07:30 AM
Laminate flooring: when to install? Phrunes Repairing/Replacing Floor &/or Frame 2 06-07-2011 05:52 AM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
