Old 12-06-2003, 09:02 AM   #29
I am at that stage also, and decided to cut the carpet plumb with the cabinets.
I do not see anything to be gained by removing the cabinets except an insignificant weight loss; than there is the elevation problem in getting the replacing rivets to go into the original holes after the carpet thickness dimension is is subtracted from the height.
Dick
Navigator is offline   Reply With Quote
Old 12-06-2003, 11:51 AM   #30
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
DENNIS- sure looks good...what are you doing for the tables that mount in the floor holes? Do you have those also, if so are you planning to cut the hole in the pergo? Are you remounting the barrel chairs as well?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-06-2003, 02:51 PM   #31
2012 25' FB Flying Cloud
Carpet
We have a 1995 Sovereign with carpet and I want to do a Pergo or some other similar floor. Our carpet runs under the cabinets. The cabinets are installed over the carpet. Do I cut the carpet at the cabinet or try to get the carpet out from under the cabinet. I do not care if there is carpet under the cabinet.
Thanks for any help.
Phil
Scaler113 is offline   Reply With Quote
Old 12-06-2003, 04:26 PM   #32
87MH's Avatar
1978 31' Sovereign
Images: 292
Carpet and Cabinets
Phil:
On the '87 tack strips were installed just outside the cabinet line (exactly as in home construction) and the carpet was just laying loose under the cabinet on the back side of the tack strip. Hopefully it will be similar on yours. Taking the carpet out should be a piece of cake. I used fairly wide trim pieces on the Pergo up against the cabinets. It's hard to get Pergo closer than 3/8" to the sides due to the board to board latch mechanism.
Peter:
Already installed a granite table top. I did not have any recessed holes for any previous tables. Bought a Pedastle and top and bottom mount from PPL, just screwed the bottom mount in through the Pergo, made a hell-for-stout wooden top support for the granite and trimmed it in oak. I cut down the size of the table 2" in both width and length. The 2" made a big difference in sitting comfort and kitchen mobility.
Barrel chairs will not be utilized. Really never utilized them prior to the redo. We have never travelled with more than four people total.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-07-2003, 11:06 AM   #33
Carpet Removal
Dennis,
Thanks for you reply on carpet removal.
Phil
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 11:35 AM
Feedback needed for real wood cabinets yukionna Cabinets, Counter Tops & Furnishings 49 05-11-2004 08:45 AM
Wood Veneer Furniture Project joshua32064 Cabinets, Counter Tops & Furnishings 5 10-05-2003 12:52 AM
Carpet Squares Don in E Texas Repairing/Replacing Floor &/or Frame 1 07-04-2003 07:43 PM
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 10:25 AM
