Old 06-06-2005, 09:58 AM   #1
tjj's63's Avatar
1963 28' Ambassador
Orange , California
Thumbs up Can I use Composite tile for flooring?
I currently have carpet (ugh!) that is glued to the original flooring. I want to replace it with Armstrong Composite tile, but in reading through some posts, I saw that most of you are using a form of sheet flooring or stick tile. Is composite the wrong way to go? I like the look of it as well as all the colors you can use.
Teresa
tjj's63 is offline   Reply With Quote
Old 06-06-2005, 10:02 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Composite tile floors are a totally acceptable flooring solution.
Some even prefer them over the sheet products, as you can line up the seams of the tiles with the seams in the floor below, which can reduce the possibility of cracking down the road.
Shari
Old 06-06-2005, 10:06 AM   #3
fireflyinva's Avatar
1961 22' Safari
Vienna , Virginia
Teresa,
We considered using composite tile, but decided against it because it is so very, very heavy (we ended up getting linoleum tiles, which are considerably lighter). On the plus side, it is very durable and not very costly. I've seen it in trailers and it does have a nice vintage appearance, closely resembling the old asbestos tile Airstream originally installed. If you use it, you can special order (from your local building supply center) it in a thinner tile--that will reduce some of the weight.
Mary
Our Airstream adventure continues!
Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 06-06-2005, 10:31 AM   #4
tjj's63's Avatar
1963 28' Ambassador
Orange , California
I just pulled out an old box of 9 x 9 tiles I got at an estate sale- cute as can be- white with green, grey red, yellow & black, but they are made with asbestos. They would be perfect- they aren't too heavy and somewhat flexible. Is there a product out there similar to these? The box says "armstrong exelon tile vinyl plastic asbestos".
Old 06-06-2005, 11:14 AM   #5
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
We used the Armstrong commercial tile. I describe and show photos here: http://www.airforums.com/forum...t=14357&page=3
in post #43.
I like the way it looks.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 06-06-2005, 02:12 PM   #6
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
It takes about 6-8 hours for me to lay a self-stick tile floor in my 34'. Thats all the way forward to the edge of the bedroom. I have put in two floors and removed the carpet and one set of self stick vinyl tiles. Put it down and if you like it fine if you don't, then remove it and use another product. I now have laminate wood flooring and love it, but then I loved the vinyl too.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Vinyl Tile Too Heavy? fireflyinva Repairing/Replacing Floor &/or Frame 14 08-15-2006 10:25 PM
Linoleum Tile On Sale fireflyinva Floor Finishes 5 07-21-2004 07:57 PM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 07:56 PM
Tile Floor billhabing Repairing/Replacing Floor &/or Frame 10 04-19-2003 01:08 PM
Bathroom tile ALANSD Floor Finishes 2 03-07-2003 12:12 AM
