Teresa,
We considered using composite tile, but decided against it because it is so very, very heavy (we ended up getting linoleum tiles, which are considerably lighter). On the plus side, it is very durable and not very costly. I've seen it in trailers and it does have a nice vintage appearance, closely resembling the old asbestos tile Airstream originally installed. If you use it, you can special order (from your local building supply center) it in a thinner tile--that will reduce some of the weight.
Mary
Mary Dotson, WBCCI/WDCU #9026
Our Airstream reconstruction adventure continues!  Read the details at Tales of the Toaster
