Old 11-04-2006, 05:27 PM   #1
2008 25' Safari FB SE
Spicewood , Texas
Unhappy bubbles in flooring
I HAVE bubbles in the flooring up near the bed and closet area on my 2002 ccd.WHAT'Sthe fix?
kingfisher is offline   Reply With Quote
Old 11-04-2006, 05:45 PM   #2
Mackhopp's Avatar
2005 28' International CCD
Ottawa , Ontario
Can you post any pictures?
From above and side view?
-Michelle
Mackhopp is offline   Reply With Quote
Old 11-07-2006, 09:31 PM   #3
Spicewood , Texas
bubbles
you couldn't make them out with a picture
Old 11-07-2006, 10:38 PM   #4
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
If you can't post a picture, how about further information? Big bubbles? Tiny bubbles? Do they appear in the surface of the flooring (what kind is it?) Do they seem to be under the flooring and making the flooring bubble? Are there any water lines nearby? It could be as simple as the lineoleum (?) flooring not being glued down properly... or it could be something totally different. Tell us all you see and know!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 11-08-2006, 04:07 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You could probably fix it like they do in a household lineoleum floor. Single edge razor blade - cut an X in the bubble - dab vinyl tile adhesive into the opening - or use a syringe. The less you bend back the cut edges the better. Let it set for at least 30 minutes then roll it with a wallpaper seam roller.
Flooring ideas ALANSD Floor Finishes 47 02-25-2012 01:20 PM
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
Great Flooring Price melprice Floor Finishes 0 07-08-2002 08:48 PM
Replacing the flooring - 61 Bambi 61BambiCanada Upholstery, Blinds, Walls & Interior Finishes 2 06-10-2002 07:59 AM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
