Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Prev Previous Post   Next Post Next
Old 04-14-2009, 01:30 PM   #1
aluminauti
whitelight's Avatar
Profile:  Where we , Park it!
Question Bridging Staples on plywood floor joints - leave or remove?
We removed all of the carpeting on our 1996 34' front kitchen. We're preparing the plywood floor for the installation of commercial grade vinyl plank flooring.
The plywood (yes, thankful it's plywood!) is in great shape & the floor level. We only found one screw elevated above the floor, which we tightened down. All of the carpet pad staples have been removed.
The joints between the plywood sheets are surprisingly smooth. We will fill the individual screws to plywood level.
There are staples bridging each sheet of plywood (picture below) - What is the purpose of these staples? Were the staples used to tack the plywood together during construction until the flooring sheets was screwed in place? Can the staples be removed without dire consequences to the integrity of the floor? Do we leave in place, just drive down to floor level & overfill?
When we removed the side couch to lift the carpet, we found spent rivets & aluminum shavings & hole plugs left over from the manufacturing!
Name:	96 airstream plywood floor seam.jpg
whitelight is offline   Reply With Quote
carpet removal, floor repair, staples
alternative to plywood re-floor? fotochop General Interior Topics 11 01-03-2008 09:42 PM
Plywood floor change. Airstream69Boy Repairing/Replacing Floor &/or Frame 1 01-03-2004 08:25 PM
Sealing Plywood For Floor 63 Safari srgntpepper Repairing/Replacing Floor &/or Frame 38 09-16-2003 10:31 PM
Forget the plywood floor... Robert Repairing/Replacing Floor &/or Frame 0 08-18-2003 06:17 PM
End Joints in New Floor melprice Floor Finishes 3 07-12-2002 12:16 PM
