09-15-2012, 08:26 PM
Phoenix
Best new flooring???
What started out as interior floor vacuuming quickly progressed to ripping out the 40+ year old carpet, padding and tack strips. Now what to do? There are some water stains on the wood. I'm wondering if I can treat them in some way, or if I should replace those areas?
Then what would be the best flooring material to put down; linolium, wood, carpet? What are the advantages and disadvantages of each.
My Airstream has the original of most everything. My problem is that many of the finishings are plastic and seem cheap. Some are cracked. I'm more inclined towards my own style than I am about keeping it original. In looking at pictues others post it seems a lot of folks change it to their own colors and finishes. Is there any real advantage to keeping all the original stuff?
Thanks for your help?
09-15-2012, 09:09 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Probably the best flooring to put down in an vintage Airstream is marmoleom because it is seamless and waterproof. However I did not want a colored vinyl type look for the floor. I considered wood, engineered wood, laminate and cork flooring. All of these flooring materials can not get wet, and have their pros and cons. In the end I went with a cork floor because I liked the look and feel of it and it was a floating floor. This to me meant that if for whatever reason, I did not like the floor down the road, I could easily take this floor out and replace it with another floor. My plywood subfloor was 46 years old and quite solid. I applied 3 coats of polyurethane to protect the original wood plywood floor. This also helped in installing the interlocking cork floating floor because the surface was slicker. Now I believe this type of interlocking floor is difficult to install in a small area like a trailer. It interlocks quite well when you have lots of room to work with. You need the room to use a protective hammering piece plus a 2x4 wood piece plus room to swing the hammer. When you don't have room to work with it can be very difficult to lock the last edge pieces. I have actually finished the installation but still have 3 pieces that I have not finished locking in completely. Hopefully I will be able to get these last pieces locked in as soon as we return from a weekend camping rally at Highland Haven Airstream Park. In the end, I recommend choosing the flooring that you like the best. Also recognize, that any flooring that is installed with nails or adhesive is much more permanent than a floating floor and will be much more difficult to change out down the road.
Dan
09-15-2012, 09:53 PM
1976 23' Safari
Mountain Home
, Arkansas
I just recently bought an airstream too and have the exact same questions, so glad you asked them. I plan to pull out the old carpet this week, went to Lowe's, Home Depot, and researching the internet to find the right flooring to replace. So maybe we can keep in touch, on ideas of updating. So much to choose from.
Leslie
09-15-2012, 11:32 PM
Ottawa
, ON
Stains on the wood floor don't necessarily mean there is a problem with the wood. Check for softness; the wood needs to be hard to endure.
What you read above is all true, many interesting floors can be done, but of course, the nicer ones all have steeper costs.
Lots of negatives with carpet, but to get by for a few years until you really figure out what you want, you might be pleasantly surprised at how cheaply you can get new carpet installed, and it's hard to deny that it feels wonderful on bare feet...
Not to mention that it will really dress up your trailer.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
09-16-2012, 08:01 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I am using wood grain floating vinyl, and Berber carpet. More vinyl than carpet.
As far as the stains, take an ice pick and poke around along the edges of the wall and see if there are any soft spots hidden underneath it. Sometimes you get water stains from condensation, old leaks that were fixed or someone dropped a beer or two.
As far as interior decor, do what you want. On my 1975 I am going back with pretty much an original interior with some minor upgrades. On my 1981 it is going to be full blown custom.
Aaron
WBCCI #XXXX AIR #2495
09-16-2012, 08:44 AM
1982 34' Limited
Brunswick
, Georgia
After I purchased my AS, I pulled up old carpet and pergo installed some time ago by the PO. It smelled awful...apparently some unresolved leaks were finding there way under there.
I aired it out, sprayed with bleach then painted the subfloor with an epoxy paint. I installed antique heart pine engineered flooring (nailed not glued). It looks great and has performed very well. I just put a small rug in the living room area, I figure that I can replace when it gets worn/dirty.
There are many good options as mentioned in the previous posts. I have seen both cork and marmolium/VCT type products that have also looked great.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
09-16-2012, 08:45 AM
Phoenix
Thanks for all the great information. Love the polyurethane idea to protect it.
Love the look of the floor and the whole decoration theme C Lewis. Makes me for sure want to go with my own style and not original. I really don't think I can live with all the breaking plastic.
Decisions decisions decisions!
09-16-2012, 09:19 AM
1987 25' Sovereign
Fort Collins
We had a similar situation. Painted floor with polyurethane sealer and after looking at all the options we could find decided on Flor carpet squares. Pros: floating; looks great; lots of colors and styles; easy installation; squares can be pulled up and taken out to dry in case of spills or replaced in case of stains; low nap style easy to vacuum. Cons: regarding performance: none found yet after a year; but generally available only on line at Flor web site, and the online colors may be misleading. We ordered some samples and our last online choice turned out to be the ideal color when we saw it "live."
We are happy with the choice so far ...
Alumacoot
“We are confronted with insurmountable opportunities.”
09-23-2012, 03:47 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
When we were restoring our truck camper we had the same issues, plus the PO used for hunting and it was a heavy smoker and that was a killer for both of us.
We were recommended to use Shellac Primer to treat the wood. Not only cover the stains and killed the odor but it acts as a sealer against mold the humidity, we are very happy with the results.
Here is a link:
White Pigmented Shellac Primer
Also what everyone is saying is totally true, specially wondering where the stains are coming from.
Regards
Still One Nation under GOD
2 chronicles 7:14
09-24-2012, 12:04 PM
1981 31' Excella II
New Market
, Alabama
Latex Porch and Floor is a good foundation for any floor covering or use it just like it is. My floor was stained and nasty after 30 yrs or being covered with shag carpet and god knows what rat fluids. We are using the bare painted floor at the moment and it looks fine with some throw rugs. At some point when I am 100% certain there are no more leaks, I will cover it with something. I suspect some sort of laminate. I am not for wall to wall anything that traps in moisture and is not removable for inspecting the sub floor.
Perry
09-24-2012, 12:54 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Be careful about "sealing the wood" with polyurethane or porch sealer if you are going to be installing sheet Marmoleum, vinyl or other glue down products. The glue for the finished floor material may not stick or be incompatable with the wood sealer. One of two things may happen...the glue won't stick or it could chemically react to the sealer and be a mess.
When we had our Marmoleum installed, we did all the prep work ourselves to keep the cost down, but had a professional install the actual product. He said it had to be installed to the clean (uncoated) wood, if we coated the wood with anything he would have to remove it before installing the Marmoleum in order for the product & installation warrantiesto remain in effect.
Shari
09-24-2012, 08:10 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Thanks for the warning about sealing the wood.
I am not disagreeing with you, but I would think that following the instructions for the manufacturer of the adhesive would also be in order. I would think that roughing up the surface with sand paper would provide an adequate surface for the adhesive, but then again maybe not.
Anyway I don't have to deal with this problem now as I have just finished installation of the cork floating floor. Here are some photos of the finished cork floor (except for installing the trim covering the 1/8" gap around the edge).
Dan
09-24-2012, 08:26 PM
2004 28' Safari S/O
Tifton
, Georgia
That looks great. Thinking of doing mine in a similar fashion. I just have a S/O to deal with. Also has anyone ever put heating strips down? A heated floor on cold mornings should would be nice !
10-13-2012, 09:27 PM
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
Dan
Hi Dan
That is a very good lookin floor! wondering what wre you [lanning on doing for "the gap"
Again, it looks great!
2 chronicles 7:14
10-14-2012, 05:40 AM
1999 19' Bambi
Cape Canaveral
Question about "floating floor".
Hello everyone. I have a question about the floating floors everyone is talking about.
My Airstream is a 99 and has the original carpet. New flooring is in my future. It seems that the trailer was built, carpet laid and then the interior installed. Carpet is under everything.
If I want to do it right I am going to have to remove all the interior, install new flooring and putting it all back together.
How much floating will the new floor actually do when it is bound by all the furniture and cabinets?
10-14-2012, 09:46 AM
Ahem, yasss ...kaff-kaff
1969 27' Overlander
Bloomington
, Indiana
After a summer living with carpet, I have decided on glue down cork, primarily from having installed it successfully in building projects. My thinking is I won't be gluing it directly to the sub floor, rather I'll staple 1/4 inch plywood underlayment first. The ply will also be the good stuff ($20/sheet!) because it has no voids in the core. I'll fill the seams and any other surface defects with a latex floor leveling compound because any imperfection will "telegraph" through the cork. Has anyone done it this way? I would go the floating route except for bad experiences getting it to lock together in tight spaces where a "persuader" can't be used.
Egad!
10-14-2012, 10:06 AM
1972 31' Sovereign
Fort Bragg
, North Carolina
We went with Pergo floating from Home Depot. It locked in pretty easy, but it did take allot of extra material to make those cuts, not including the ones you cut too short.
The original floor was water stained but very solid. WE replaced carpet twice, but after a water incident and a relocation to a warmer climate found that the floating floor worked for us. It does allow for retraction and expansion, so that it very good based on climates and humidity.
We looked at going with the more solid floor as the time invested when placing a floor down is time consuming and you hope to only do it once. What was also a consideration was the weight. The difference between the carpet and the new Pergo floor was about a 45# increase which I thought would be allot more.
On the "plastic" veneer replacements. This can become very expensive to replicate to replace. Again, the weight can add up real quick. We were considering going with some lighter in weight material, like teak in some area's. The cost is amazingly expensive. Even a 24" x 40" table ran about $375 w/out a high gloss finish. check around as some RV furniture companys still make these items for a cost, but the shipping may be worth the expense.
Good luck, some great idea within this thread and some great pics that help visualize how and what to do.
10-14-2012, 10:18 AM
2006 25' Safari
St. Augustine
That is a beautiful cork floor. I believe that cork is probably the best floor for a trailer. Wetness just does not do well with anything else that is lightweight too. TouringDan, that floor is nice. I would not choose Pergo. Just living in FL and seeing issues in homes with water and sand are enough to steer away from that one. I know lots of people on here use it but in their fine print they also suggest a non-wet area with regard to warranty.
Good question Luc, mine too has carpet under everything in the bedroom where they installed carpet at least. How does one deal with that? I installed carpet only in the walking area as an animal had used the potty between the twin beds and it was stained when I bought it but I came close to going with cork.
Also, question for you corkers, is it possible to cork over the laminate? Would you?
10-15-2012, 10:23 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
RH
I believe if you use a cork floor that you do not need heat strips. We just returned from a camping trip down the Blue Ridge Parkway and it got into the low 30's at night. I did not even bother putting my slippers on when I had to get up in the middle of the night. So I believe adding heat under cork is not needed, and if it is not necessary than it is necessary not to install it. You don't need the complexity, the weight or anything else that comes with it. Remember that "new solutions have new problems" Also, you are going to heat it with electricity. We were boondocking, so no 120v ac! Just my opinion.
Dan
10-15-2012, 10:29 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Originally Posted by VeggieBullet
Hi Dan
VB
Thanks! Glad that you like it.
If you look at posts 3-7 of the following link about my 66 Tradewind improvements you will find the details of how I installed the floor and covered the 1/8" gap. Basically, I used a 5/16 x 3/4 base shoe that I cut down from 1/2 x 3/4 base shoe.
http://www.airforums.com/forums/f116...nts-94152.html
Dan
