Old 03-05-2017, 10:31 AM   #99
2012 25' FB Flying Cloud
albany , Georgia
And the Lowes page for it.
https://www.lowes.com/pd/SMARTCORE-b...lank/999901235
jmpgino is offline   Reply With Quote
Old 04-14-2018, 10:12 AM   #100
1986 29' Sovereign
Chanhassen , Minnesota
Hello 911 Patriot, I'm also considering lining my shower with aluminum sheet to new walls. Can you respond to
1) what aluminum was used? Source?
2) Are you happy with the long term cleaning / maintenance of the shower?
3) any advice (pro or con) related to sealing the shower.
Thanks in advance, Scott
Harrysheets is offline   Reply With Quote
Old 05-14-2018, 09:58 AM   #101
1976 Argosy 28
San antonio , Texas
I am following up to see how the floor is holding up? We are looking to add a finished floor to our 1975 Argosy, and we are leaning very heavily on the Smartcore product.
Thankx
Whit461 is offline   Reply With Quote
Old 05-15-2018, 06:51 AM   #102
1997 30' Excella
Corpus Christi , Texas
Update on luxury vinyl flooring
2.5 years later and it’s great. No buckling at all. No rips - nothing. We had a toilet leak and had to pull up the entire bathroom and part of the bedroom. All of the pieces went back down perfectly. Love it!
Knudsvig is offline   Reply With Quote
Old 05-15-2018, 08:33 AM   #103
Denver , Colorado
Shaw Floorte
I installed Shaw's Floorte floor a year ago. Very happy with the quality of the product.
Globeville is offline   Reply With Quote
Old 05-15-2018, 11:48 AM   #104
1976 Argosy 28
San antonio , Texas
I have samples of both in the truck to take home tonight. Let's see what DW says. There seems to be height and stiffness differences.
Old 05-23-2018, 05:41 AM   #105
1995 30' Excella
Harper Woods , Michigan
My choice will be interlocking polyurethane foam floor mats. They come in many colors (and woodgrain), and even in a formulation that can withstand combat boots during martial arts training. They are waterproof, insulating, and can be taken up & out for cleaning and floor inspection.
This company has many products - even flooring for horse stalls.
https://youtu.be/WtCKHcqgD4c
Bob Blarney is offline   Reply With Quote
Old 05-30-2018, 12:37 AM   #106
2006 28' International CCD
Palm Spings , California
Originally Posted by Dan and Liz View Post
We had a similar situation. Painted floor with polyurethane sealer and after looking at all the options we could find decided on Flor carpet squares. Pros: floating; looks great; lots of colors and styles; easy installation; squares can be pulled up and taken out to dry in case of spills or replaced in case of stains; low nap style easy to vacuum. Cons: regarding performance: none found yet after a year; but generally available only on line at Flor web site, and the online colors may be misleading. We ordered some samples and our last online choice turned out to be the ideal color when we saw it "live."
We are happy with the choice so far ...
May I pick your brain?! I’m considering Flor for my ‘06 28’ Interstate. Do you remember how many carpet tiles you purchased for your trailer? How did you figure it out? Are they easy to cut?
Thank you!
Waynestream is offline   Reply With Quote
Old 08-04-2018, 08:00 PM   #107
NHdigger's Avatar
2008 25' Safari FB SE
Milford , New Hampshire
Completed the installation of new LVP flooring and a new oak dinette table that I made to update the interior after 10 years.
The flooring is made by Engineered Floors and comes in planks with butt joints. After reading the pros and cons of "click Joint" and glue down floors I wanted something different. It can be loose laid or glued down and I liked the loose lay option in case a section has to come up in the future. The floor can be cut with a razor knife or jig saw.
I did all the removal & re-installation of the furniture and wisely paid a pro to install the flooring. So far I'm happy.
ID:	318892   Click image for larger version
NHdigger is offline   Reply With Quote
Old 10-16-2018, 07:04 PM   #108
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Safari Wall to Wall
Here is our ad to this post. Carpet installer measured, cut and bound four pieces for our 23FB. Can remove door or oven area to have cleaned separately.Plus, pattern hides a lot of "mess".[ATTACH]Click image for larger version
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 11-03-2018, 06:34 PM   #109
2000 31' Excella
Ontario , Canada
Smile Is this the best of the best???
Luxury vinyl planks
virgin pvc ?
100 % waterproof
Can be installed in any floor of your house and in 3 season cottages
tolerates -4 F to 122 F
Floating installation
foam backing
hides subfloor imperfections
pet tolerant
wood grain finishes
residential lifetime and light commercial 5 years warranty But not in a RV.
and a bunch of other stuff.
about 3.50 sq ft
sells under a few brands including Peerless
The stuff we are looking at is Cove Mcway 2141
Anybody used this or know someone who has??? How about a great competitive product?
woodytwo is offline   Reply With Quote
Old 11-30-2018, 06:53 PM   #110
2000 31' Excella
Ontario , Canada
had this flooring installed a few days ago by experienced floating LV plank installers. Took them (2) 1 and a half hours to install everywhere but the bedroom and under the front couch of a 31 classic. lots of corners to go around. I had removed the existing trim, the carpet in front of the couch and the toilet. weather was just on the freezing mark and I had the interior heated to 65 F. that was 4 nights ago. weather is still cold with no interior heat and floor is still in place. Next steps are to replace trim and drive to Florida next week. But so far I'm happy. I'll update next April when I return to Ontario.
Old 02-19-2019, 07:35 PM   #111
VDR928's Avatar
2012 23' FB International
Charlotte , NC
Lifeproof Rigid Vinyl Planks
We recently laid new flooring in our 2012 International Serenity. We chose a Lifeproof brand, rigid vinyl plank floating floor in "Sterling Oak". We love it and it went down a dream. It completely locks together, leaving no showing seams, and is "waterproof". It seems very strong and durable. I highly suggest it for anyone wanting to change out their floors. It took us 3 weekends to do it right (under bed, taking out dinette, etc.)
ID:	333993   Click image for larger version
VDR928 is offline   Reply With Quote
Old 03-16-2019, 01:29 PM   #112
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
We used this flooring. We removed the flooring down to the sub flooring to correct a hump in the flooring. Click image for larger version
ID:	335829Click image for larger version
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
