Old 11-18-2015, 08:40 PM   #85
1955 26' Cruiser/Overlander
Flor Tiles
I just bought a 1955 Overlander and the PO put down Flor tiles over the existing peel and stick tiles. from the few spots that I've inspected that typically have water damage, there is staining but no rot. (keeping fingers crossed) Eventually I'd like to replace the carpet with something a bit more water/stain friendly, as I'm now a full-timer, but have to admit, the Flor tiles are pretty cozy, and super easy. They may just stay as I do everything else needed that comes with a vintage rig. Looking forward to seeing what you choose!
1955 Dottie // Love Is In The Air...stream
1955Dottie is offline   Reply With Quote
Old 11-24-2015, 10:28 AM   #86
1997 30' Excella
Corpus Christi , Texas
Shaw resilient LVT light commercial grade vinyl planks.
BeforeClick image for larger version
Name:	ImageUploadedByAirstream Forums1448386099.457833.jpg
AfterClick image for larger version
Name:	ImageUploadedByAirstream Forums1448386115.757366.jpg
ID:	252803Click image for larger version
Name:	ImageUploadedByAirstream Forums1448386128.362943.jpg
Knudsvig is offline   Reply With Quote
Old 09-02-2016, 03:49 PM   #87
2011 30' Classic
Burlington , Ontario
In the AS Classic Limited 30 ' 2011
Is there flooring under the carpet in the ASClassic Limited edition 2011!
Has anyone taken out the carpet in the living room and found the same flooring that is in the kitchen and dinning room? We have disgusting carpet and would like to remove, however quoted a $3000.00 price to replace the flooring through out. Thanks in advance.
carol1farr is offline   Reply With Quote
Old 10-07-2016, 11:56 AM   #88
Tinbox
Tinbox's Avatar
1964 19' Globetrotter
Panama City , Florida
Has anyone know how to remove the flooring from a 2014 airstream sterling?
Tinbox is offline   Reply With Quote
Old 10-08-2016, 07:47 AM   #89
2011 30' Classic
Love it. Exactly what we want to do.
Old 02-13-2017, 02:01 PM   #90
2012 25' FB Flying Cloud
albany , Georgia
in my opinion putting down wooden laminate flooring in a TT, is asking for trouble. Bamboo is especially a bad choice.
Now vinyl click lock planking that floats, may sound great until you look at every section regarding installation instructions, for each company. They all call for temperatures between50f and 85f and if any lower or higher and they warn you of trouble. I have been searching and searching and have found a company that has a vinyl click plank that operates between 100f and 30f now that is way better than the other products out there. All of your Lowes and Home Depot stuff is in the bad temperature range for a TT, after all this stuff is intended for a home with climate control.
Shaw flooring has a new product line called FLOORTE, I have already chosen what I want and am now waiting for the weather here in Georgia to warm up.
So I strongly suggest you look at this stuff, I have been searching for three months and this stuff is the only one that can handle large temperature swings.
Just thought I would add my piece.....cheers, James.
jmpgino is offline   Reply With Quote
Old 02-13-2017, 03:25 PM   #91
Silver Spud
shadrick5's Avatar
1975 31' Sovereign
Twin Falls , Idaho
I have soaked a piece of bamboo flooring, the cheap stuff, in a bucket of water for a week with no change in size or shape. I have done the same with carbonized bamboo, expensive stuff, with the same results. Carbonized bamboo is harder than oak and very resistant to scratches while the cheap stuff will show high heel marks. I have carbonized bamboo in several spaces of my own house, golden retriever scratch free, and have installed many types of flooring over the years.
I have a leftover, cheap wood laminate in my AS that I installed 5 years ago and used tight tolerances at the edges and not the 1/4 inch recommend by the manufacturer. Our temps range from 20 below to over 100f and I have had no issues, which I knew would be the case. Disclaimers from manufacturers does not always indicate what the product can do. They are there to eliminate any liability from a lawsuit against them using the defense of improper installation.
shadrick5 is offline   Reply With Quote
Old 02-13-2017, 04:15 PM   #92
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
I too used Flor rug tiles...so nice to walk around with bare feet in our vintage trailer. If we get bored with them we can swap them out for something different, but they have held up extremely well so far including a bad coffee pot spill! We only have them in our exposed areas so the covered areas show the plywood floor. This is especially handy when checking for leaks!
http://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 02-14-2017, 10:42 AM   #93
albany , Georgia
Found a better product.
By chance yesterday I went into Lowes, i stumbled across a floor product I had not seen before. Got a sample, came home and searched its details, part of it here.....
READ BEFORE INSTALLING
While SMARTCORE is waterproof, its not a moisture barrier. Its still a good idea to make sure concrete is cured and tested for
moisture and that a moisture barrier is installed in the crawl space and even under a SMARTCORE floor over a concrete subfloor.
Moisture wont damage SMARTCORE, but it can get in the walls and structure of the home. A couple of extra dollars and a few
minutes is a small investment for the added protection and peace of mind.
Because houses and buildings, as well as adjacent hardwood or laminate floors, expand and contract, Natural Floors
recommends to leave a expansion gap between the perimeter walls and any adjacent hardwood floor.
Natural Floors recommends using the glue down method when installing SMARTCORE where it will be exposed to temperatures
greater than 140 F (60 C) or below 32 F (0 C).
Use good common sense installation practices, and youll have a successful installation that results in a beautiful floor.
Note the 140F max temp, way higher than the other product I had set myself on, so I have just ordered the stuff. Chose.....
SANDHILL OAK #749840 $3.48 per sq ft.
Old 02-26-2017, 09:09 AM   #94
albany , Georgia
New floor nearly down.
I started on Wednesday evening and today Sunday I should be finished laying the floor. Just got small spots and the bathroom to lay.
It looks superb truly superb.
I tested two pieces for hot and cold conditions, put the oven on at 140f for one piece and put the other in the freezer at - 2f
Neither piece moved, expanded or contracted. I think that is impressive and since I am in the south the high end temperature tolerance of this product is rather reassuring.
The bed area would have been an issue had I not unscrewed the bottom end from the floor. This enabled me to place a plank underneath and trace the outline, perfects fit.
I have found a company that makes fully flexable moldings and they have a quarter round that is truly a 1/4 by a 1/4 anything bigger would be out of scale.
Airstreams quality control does not match the prices they charge for their units.
On removing the toilet, I discovered the toilet flange had only six of the eight screws in the floor. The idiot who cut the access hole made it too big and the front two screws were in fresh air, someone cheekily put a bead of liquid nails over it edge. I also discovered the rubber gasket ring had a third of the tank part missing, that should not have been used.
Behind the grey floor edging I found base rivets that had not been secured properly, a number had at least an 1/8 to 3/16 of the head sticking out.
Anyhow I will post some images when I have finished.......
Old 02-26-2017, 05:44 PM   #95
albany , Georgia
Flooring tests on heat and cold.
I tested two pieces of the new flooring yesterday, one in the oven at 140f and another in the freezer at 28f The oven test was done for five hours, the freezer test for twelve hours over night.
Neither piece expanded or contracted and both were still flat. Now that is impressive and reassures my confidence in this product.
Just out of curiosity I tested a sample of the Shaw FLOORTE in the oven as well, it also did not expand or contract, even though its maximum heat was supposed to be only 100f
If anyone is looking to replace their floor covering, you need to seriously look into what I have been putting down in ours.
Cheers,
James.
Old 03-04-2017, 08:20 AM   #96
Denver , Colorado
Floorte Installation question
James, I can't see on the website how they install the product. Can you describe the installation process? Does the product come in planks? Thx.
Globeville is offline   Reply With Quote
Old 03-05-2017, 10:04 AM   #97
albany , Georgia
This is a YouTube clip I found of the stuff......
Old 03-05-2017, 10:16 AM   #98
albany , Georgia
Website.
Here is the company website.....
6ft by 7in click lock planks, floating.
http://www.smartcorefloors.com/products/
