Old 03-08-2015, 01:41 PM   #1
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
Best Adhesive for Glue Down Cork Flooring
The carpet has been pulled up on our '83 Sovereign, and am ready to start glue down cork tile installation. The manufacturer recommends a water-based contact adhesive, but that stuff is VERY expensive and the idea of working with 'one shot and done' with a contact adhesive intimidates me!
Which specific adhesive has worked the best for glue down cork flooring installation? I've thought of and heard of everything from construction adhesive, indoor/outdoor carpet adhesive, etc.
I guess we read elsewhere on the forum that only water based adhesives must be used.
Alsupp is offline   Reply With Quote
Old 04-20-2015, 08:35 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Suggest you install floating instead of glue down.
BambiTex is offline   Reply With Quote
Old 04-20-2015, 09:34 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Recommend you use what the manufactur of the flooring suggest.
MICHAEL
Old 04-20-2015, 10:03 AM   #4
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Yup use what the manufacturer recommends. I used water based contact adhesive on my glue down cork and can't recall the cost but thought it was about $35 a gallon so cheap. I found the process easy and actually really satisfying but I'm weird I guess
truckasaurus is offline   Reply With Quote
Old 04-20-2015, 10:22 AM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
gluing it down can later cause problems as the floor beneath it will contract and expand. If you can glue the edges only it might be better. I have used cork in two Airstreams and love it. My last install in our 66 is edge glued. Also leave a space around the edges near the walls for expansion.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-20-2015, 10:40 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
I used click-lock.
Old 07-15-2015, 07:32 AM   #7
1975 31' Sovereign
Lebanon , Pennsylvania
With cork flooring, did you install floor first, then furniture and walls? Or furniture and walls, then flooring in between?
mgjurina is offline   Reply With Quote
Old 07-15-2015, 03:56 PM   #8
Hoobiedoobie's Avatar
1987 25' Sovereign
Chilhowie , Virginia
Following. Pictures would be great!!
Hoobiedoobie is offline   Reply With Quote
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
Sheet flooring...Glue down or float? soldiermedic Floor Finishes 26 03-04-2010 12:55 PM
Best Way to Install Cork Flooring? highmark Floor Finishes 9 08-23-2006 08:41 AM
Solid Vinyl Tile (SVT) Adhesive Glue ? trevisgardne Repairing/Replacing Floor &/or Frame 2 04-14-2006 10:04 PM
Cork flooring ALANSD Upholstery, Blinds, Walls & Interior Finishes 5 01-14-2004 07:14 PM
