Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 03-06-2003, 08:57 AM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Bathroom tile
I tore the carpet out of my bathroom and have vinyl tile to put down. there is a lip from the toilet/sink surround that pokes out about an inch over the plywood flooring.
If I replace the round headed screws that hold it down with flat heads, and tile over it, any problem? I think the tile is resilient enought where the slight lip height will not show.
Thankfully the wood is in great shape, no rot.
Old 03-06-2003, 07:44 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Flat heads you will have to counter sink, the thickness of the plastic will have to be more than the thickness of the screw head. If you make a transition with filler around the edge of the plastic it would give more contact surface for the tile, especially the sheets that were cut fairly small.
John
74Argosy24MH is offline   Reply With Quote
Old 03-06-2003, 11:12 PM   #3
silverhawk
silverhawk's Avatar
Profile:
Images: 20
bathroom floor
try laying a subfloor of 1/4 in. luann, it should give you the level that you need.
silverhawk is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
tile under toilet Holzarbeiter Sinks, Showers & Toilets 11 04-03-2004 09:17 AM
lenses for bathroom light atvmcg Parts Archive 2 03-10-2004 11:20 PM
advice wanted for bathroom sink replacement Shelby Copeland Interior Restoration Forum 8 12-25-2003 07:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 05:13 PM
