Old 09-16-2010, 05:21 PM   #1
2003 25' Safari
Crozet , Virginia
bamboo flooring in airstream
Getting ready to install an engineered bamboo floor in an airstream travel trailer.
Question: What is the recommended method to install a wood floor in an airstream trailer.
  • The floor will be quite small say 7’ x 8’ at the largest open area and other typically small areas like 5’ x 3’.
  • The trailer will be exposed to temperature extremes like 32 degrees to 120 degrees.
  • I would like to use a combination plastic vapor barrier and pad like found at Lowes….is this recommended?
  • Do I need to do the loose laid or glue this floor down.
  • Can I use smaller gaps at the edges with such small areas to cover?
Any other recommendations would be appreciated.
dwb5f is offline   Reply With Quote
Old 09-16-2010, 06:04 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't glue it down.
Remove as much cabinetry as you can and install the flooring over this are.
Where you have to screw down the cabinets drill a 3/4 in. clearance hole through the floor and screw down through these holes. This will allow the floor to float. After 3 years I have seen no evidence of floating but the manufactures want that margin of safety.
The barrier I used was supplied by Armstrong.
2004 Excursion 4x4
Old 09-16-2010, 06:06 PM   #3
HowieE's Avatar
Images: 12
For some reason the picture did not post.
2004 Excursion 4x4
Old 09-17-2010, 02:56 AM   #4
rovercamper's Avatar
Grottoes , Virginia
Hey Howie, what type of molding did you use around the borders? There doesn't look to be many straight lines in these trailers - like around the door, with all the little ins & outs. Wondering what works best.
rovercamper is offline   Reply With Quote
Old 09-17-2010, 07:35 AM   #5
HowieE's Avatar
Images: 12
Another nice thing about removing as many of the cabinets as possible is you loose a lot of cutting and fitting. I did not remove the kitchen cabinet so that became the starting point working along that edge and filling to both sides.
I used 1/4 round prefinished molding that closely matched the floor color. Total molding was about 6 feet, just a long piece along the toe kick of the kitchen cabinet, 18 in. along the edge of that cabinet by the door and 3 in. from that cabinet to the door frame. No picture of the molding areas. Under the stove there is an air access for the furnace and I just extended the flooring into that area a couple of inches no molding as the edge just disappears there. My trailer has a velvet wainscot on a backer board in the living room and that covered the exposed edges of the 1/4 in. setback required for a floating floor so no molding there.
2004 Excursion 4x4
Bamboo Flooring timmy67 Repairing/Replacing Floor &/or Frame 14 03-24-2016 07:56 PM
2003 25' Airstream Safari - Twin Beds - New Flooring eBay Watch Airstreams on eBay 0 03-02-2010 01:40 PM
I install vinyl flooring in 83 31' Airstream ww0o Floor Finishes 2 06-27-2007 08:06 PM
Bamboo floors M&J Siegford Floor Finishes 27 07-04-2005 06:29 AM
Bamboo floor replacing carpet Pahaska Floor Finishes 28 05-30-2005 09:48 PM
