Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 10-10-2004, 07:23 PM   #15
gklott
gklott's Avatar
Profile:  2004 30' Classic
Johnson City , Texas
Images: 31
Why did you decide to not replace carpet areas?
Any idea on the weight increase?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic dinette
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 10-10-2004, 11:28 PM   #16
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Why?
73/gus
I assume that this was directed to me.
I like carpet in the bedroom and I like it in front of the couch where I lounge in stocking feet. I just don't like it by the entry door or in the galley area where it gets filthy very quickly. That said, I wish the remaining carpet were something such as Berber that shows less soil.
Also, it would be a pain in the a** to lay flooring around the queen bed; it would be all little short pieces.
I doubt that I added any appreciable weight, certainly not over 10 pounds at the most. Carpet and pad are surprisingly heavy. The new flooring is not very thick; much lighter than some of the laminted products.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-11-2004, 06:53 AM   #17
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
You know John as the process started, I was a bit skeptical, but in the back of my mind, I told myself, this is mod man John Irwin, of course it was gonna look good in the end. True to form, the end results are outstanding.
When is the berber project?
I agree about not having carpet installed in the main traffic areas. I noticed that in 2004 Airstream started to ease off the carpets. Our Safari has only carpet by the sofa. Just as a side note, most of the Classic line has adopted the overall concept of what you have done as well (no carpet at the doorway and main traffic areas, while keeping carpet by the rear bed and front sofas). There are two or three models where it is an exception and carpet is in the areas, but I digress........yours looks great!
Old 11-11-2004, 12:13 PM   #18
M&M CAPECOD
M&M CAPECOD's Avatar
Profile:  2002 28' Classic
Cape Cod , USA
Images: 21
Hello John,
Now that some time has passed since you've installed the bamboo I would like your honest opinion on which product (the cork or the bamboo) you prefer, all things being equal. Which floor is the easiest to maintain? most durable? easiest to install? etc. Has the color deepened? Is there anything you would have done differently? I can't remember if you used prefinished cork and bamboo, I have heard that you can get a longer wear if you have it finished after installation. Your opinion would be greatly appreciated.
Thanks for letting me pick your brain .
Mary
"A dream becomes a goal when action is taken toward its achievement." -Bo Bennett
WBCCI #9204, Region 1, New England Unit
'02 Grey Lady, 28' not so Classic anymore
'08 GMC Sierra 2500 Duramax/Allison Crew Cab
M&M CAPECOD is offline   Reply With Quote
Old 11-14-2004, 11:51 AM   #19
Pahaska
Pahaska's Avatar
Images: 12
In retrospect
Originally Posted by M&M CAPECOD
Hello John,
Mary
The bamboo is prettier, but the cork was easier to keep looking clean. Every litle thing shows on the bamboo where the cork could get quite dirty without it showing. OTOH, I think the bamboo goes a lot better with the real woodwork in the Classic whereas the appearance of the cork fitted the laminates in the 22' better. In both cases, I use a wet "Swiffer" to do the floors.
I did use pre-finished materials. Maybe if someone was living in the trailer full time, wear could be a factor, but I think that both materials are more than wear resistant enough for the way we use the trailer. If I were to choose just for wear resistance, I would pick the cork.
John W. Irwin
Old 11-15-2004, 04:36 PM   #20
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
From This Old House I am aware that much prefinished flooring has fine aluminum oxide incorporated in the finish to prevent wear-through. This is the same hard material used as an abrasive in garnet sandpaper (the red colored stuff). I'm not wild about some of the ripple finishes, etc., but has anybody had quality complaints of wearing through the finish?
Finding thinner coverings takes some doing. The floors at Home Depot get thick and heavy pretty quick -- to say nothing about the lack of real wood and obviously photo-reproduced appearances...
Old 02-26-2005, 03:28 PM   #21
LuminumTraila
LuminumTraila's Avatar
Profile:  2006 19' Safari SE
NW of Boston , Massachusetts
Wink I love this forum!
Just got back from Lowe's where we went to look at some things for our '76 Safari. I saw the bamboo flooring and thought Wow! this would be great for replacing the old carpet. Got home and came to the forum to see if anyone had done it and found this thread. Fantastic job, Pahaska! And thank you so much for documenting your project.
LuminumTraila is offline   Reply With Quote
Old 04-14-2005, 05:38 PM   #22
Warbs
1977 28' argosy moho
Profile:  scarborough , ontario
aluminum oxide finishes
We put prefinished 3" wide hardwood all through our house two years ago. Two adults, two kids, a dog and two cats haven't dulled the finish a bit. It's got 15 coats and is guaranteed for 25 years. We're very happy and would recommend it to anyone.
Warbs is offline   Reply With Quote
Old 05-30-2005, 07:55 AM   #23
Swanny
Swanny's Avatar
Profile:  1990 34' Excella
Windcrest , Texas
What was the part number of the bamboo flooring?
Originally Posted by Pahaska
I bought it at Lowe's. They had a display board in the flooring dept with twocolors: blonde and carbonized. I chose the carbonized. They don't stock it in the store, but it came in about 10 days.
I found that Pergo cherry trim matched the floor color perfectly.
What was the thickness of the bamboo you ordered or better yet was there a part number associated with it? Also did you put down a sub-floor?
I'm asking about the sub-floor since I went to the I-floor website and their installation procedures were somewhat intimidating. They were talking about keeping constant humidity and temperature level, etc. Thanks again!
Mitch
Texas Streamer
1990 Excella 1000---34'
WBCCI #18303
2005 F-350 Diesel 4 X 4
Swanny is offline   Reply With Quote
Old 05-30-2005, 08:02 AM   #24
Pahaska
Pahaska's Avatar
Images: 12
Mitch
I would guess it was about 7/16" thick. No idea of a part number. I saw it on a display at Lowe's and liked the color and price, so I ordered two boxes.
I laid the bamboo right over the plywood flooring. There were big staples where the plywood sheets joined; I pounded these down a bit with a hammer, but the thickness of the adhesive was enough that there was no print through of the staples.
John W. Irwin
Old 05-30-2005, 05:12 PM   #25
HitnMiss
Profile:
Wink
John its been another 6 months since your last retrospective, I know you have put a few road miles on the trailer since then. Anything to report as to gaps, or any type of flooring probs with the bamboo overlay?
Also did you use 1/2 inch or 1/4 inch quarter round?
Also could you explain the need for and the definition of a "dead blow" hammer.
Flicka
HitnMiss is offline   Reply With Quote
Old 05-30-2005, 06:32 PM   #26
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
We're putting down a wood floor. We want to put it down right over the plywood with some subfloor adhesive and a brad nailer. Did you use anything except the "glue"? What kind of glue are you talking about?
juel is offline   Reply With Quote
Old 05-30-2005, 09:22 PM   #27
Pahaska
Pahaska's Avatar
Images: 12
No problems whatever. All joints are tight and there are no squeaks. Some scratches from gravel tracked in, but not severe. I try to keep a good coat of wax on it.
I used the Pergo quarter round trim which, as I recall, must be about 5/8" or 3/4". The cherry finish matched my bamboo color quite well.
It is a plastic hammer full of BB shot. It is fairly heavy, but does no damage even with a hard blow. I found it invaluable in seating the interlocking joints tight or moving a plank a fraction to get a tight end joint.
Flicka[/quote]
John W. Irwin
Old 05-30-2005, 09:31 PM   #28
Pahaska
Pahaska's Avatar
Images: 12
I used a water soluable floor mastic I bought at Lowe's. I also used the brad nailer very sparingly. I nailed the first row adjoining the carpet and the ends adjoining the vinyl at the doorway very close to the edge so that the nail holes would be covered by the T molding. By nailing the first row, I was assured that the alignment would not change as I bumped successive planks into place.
I also used a brad several other places to insure that end joints would stay tight. The mastic grabs real quick and sometimes the planks tend to pull away from each other a bit. I would use the dead-blow hammer to tighten the joint and the elastic mastic would pull the joint open slightly after a few minutes. This was a good place to use a couple of brads on the end that would be later hidden byr the quarter round to keep the joint tight.
John W. Irwin
Replacing Carpet - Bizarre Discovery - ??? mdeneen Floor Finishes 15 10-13-2004 12:36 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 8 09-08-2004 09:08 PM
Carpet removal tips? maxandgeorgia Floor Finishes 1 08-21-2004 10:53 AM
Carpet Removal for Pergo Cstar Floor Finishes 19 07-05-2004 09:48 PM
Carpet Cleaning Advice JaceBeck Upholstery, Blinds, Walls & Interior Finishes 4 03-26-2003 10:25 AM
