Old 03-22-2011, 07:47 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Armstrong VCT - Any gluing issues with Cold?
I'm looking at keeping it vintage. I have found an Armstrong VCT tile that looks almost like my original floor, but the secondary color is turquois, which matches the fridge and stove (instead of the original gold -which is pretty hideous).
I have a friend that will loan me a VCT cutter, so my tile will be the original 9" square.
I plan on painting the floor with KILZ, then the Armstrong primer, then the armstrong adhesive.
Has anyyone had any issues with armstrong tiles popping due to cold weather? I don't plan on hauling too much during the winter, and I'm putting new torsion axles on now, so I think I'm covered, but would like feedback if possible.
robwok is offline   Reply With Quote
Old 03-22-2011, 07:54 AM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I suspect that using the glue might be the trick. We used the self-stick stuff when we redid the floor years ago, and it was a mess. Wound up removing a lot of the tiles and applying 'real' glue underneath.
Lynn
WBCCI 21043
Old 07-18-2011, 10:04 AM   #3
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Armstrong not recommended
I order some of the Armstrong VCT on saturday to tile my floor. Just spoke with Armstrong and to ask about floor prep and was surprised when told that the product should not be used where temp will fall below 55 degrees. Not sure if I'm going to try it or not. The guy actually said they make no product that he could recommend! It gets down to 20's here occasionally.
SilverHoot is offline   Reply With Quote
Old 07-18-2011, 11:20 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
I suspect that a number of household flooring glues would be such. The sticky stuff on the back of the self-stick flooring tiles was definitely that way. Looked great when applied, but then give it some nice super-hot and super-cold days (trailer in storage, unheated/uncooled), and it started popping off.
I've been using good-ol' automotive upholstery glue (aka "monkey snot") to glue down the ones that popped off. It holds.
Lynn
WBCCI 21043
Old 08-08-2013, 11:49 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Just wanted to bump this up a bit. I'm getting ready to do this. Found a cheap VCT cutter. Now that I have a heat pump installed with a thermostat, maybe I'll just have it out there for minimum and maximum temps. Anyone want to comment?
Rob
armstrong, floor, vct, vinyl
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
No cold on the road Hodum Refrigerators 3 03-04-2011 02:04 PM
67 Caravel and Armstrong Air not working vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 8 03-02-2011 01:24 PM
CB Radio issues & upgrade - suggestions? ddgall Land Yacht/Legacy Motorhomes 5 02-12-2011 08:42 PM
Any Huge Glaring Issues? Jerry Knowlt 2007 Safari SE 9 01-21-2011 06:40 PM
