Old 09-02-2016, 08:30 PM   #1
DaddysBus's Avatar
Anyone seen this kind of damage?
Good evening,
Saw this nausea inducing sight under the rubber mat I'd been using in our 2016 AI. Any suggestions for a fix or am I looking at living with this?
Thanks in advance for suggestions!Click image for larger version
Name:	ImageUploadedByAirstream Forums1472869815.279068.jpg
DaddysBus is offline   Reply With Quote
Old 09-02-2016, 08:53 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had the same issue with my Bambi II. Sand and dirt gets under the mat. Acts like sand paper. Clean it the best you can, wax and do not us rubber backed rags. Frequently remove and clean under any rugs.
MICHAEL
Old 09-02-2016, 09:59 PM   #3
2004 22' Safari
I do not know if the flooring in the AS has any poiyurethane-finish on it but I have had success in my home with a polyurethane finished wood floor in fixing such damage using a Minwax Hardwood floor Reviver product. It was pretty easy to use. Might be worth a try. HomeDepot carries a couple of other similar products.
Northerngirl is offline   Reply With Quote
Old 09-02-2016, 11:00 PM   #4
DaddysBus's Avatar
Appreciate the help! Thanks.
Old 09-03-2016, 02:55 PM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
some clear coats are water based now days. If moisture gets trapped under it will fog out like that if thats what I'm seeing.
My coffee table does that with alcohol. If I use a wax such as pledge it eventually comes back to clear.
twolanehwy is offline   Reply With Quote
Old 09-03-2016, 03:32 PM   #6
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
Toung Oil. It will displace any water or condensation. Apply, rub like hell, let dry. Do not cover with any thing till dry.
That is deck flooring (land yahat) flooring. Does not like being covered.
Try a small area first to see if you like it first.
Happy Trails.
Jekerrville is offline   Reply With Quote
Old 09-03-2016, 03:48 PM   #7
1964 22' Safari
Naples , New York
floor damage
Spread mayonnaise over the affected area. Let it sit 24 hours and then wipe it up. The haze should disappear.
Larry
lletteney is offline   Reply With Quote
Old 09-03-2016, 05:06 PM   #8
interstateflyer's Avatar
2017 25' International
Los Osos , California
"Airstream Vinyl Flooring Teak Wood Plank Style. This high quality vinyl flooring used by Airstream in Land Yacht and Interstate Motorhome".
I spoke with an A/S dealer who used the wrong type of entry mat and had to deeply discount the trailer because of resulting discoloration of the vinyl flooring.
Our new 2017 International Serenity has vinyl flooring. I'd like to know what floor mats are safe and which to avoid.
http://airstreamsupply.com/airstream...r-ln-ft-107944
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-03-2016, 10:27 PM   #9
DaddysBus's Avatar
Thanks for the tips. Going to hit it with the Toung oil tomorrow. You guys rock!
Old 09-04-2016, 01:30 AM   #10
2007 22' International CCD
N.B. It's spelled "Tung"
Pedantic PITA me, late at night.
KE4GNK/AE
Old 09-04-2016, 10:26 AM   #11
Tung oil is normally intended for wood.
Fantastic that it also benefits non-porous vinyl.
Old 09-04-2016, 10:56 AM   #12
Penokee , Kansas
I would air dry a few days.. any oil or such will make the problem worst I fear.
Sodbust1 is offline   Reply With Quote
Old 09-04-2016, 10:58 AM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I think people have given you advice assuming that your floor is real wood.
I don't think tung oil is appropriate for your synthetic flooring. It might even harm it.
I suggest you talk to the flooring manufacturer before trying anything, or you may make the problem worse.
Alan
Old 09-04-2016, 11:22 AM   #14
For our new Serenity with comfort flooring, I'll most likely avoid non-porous mats that tend to trap moisture.
I'm suspicious of the closed back Airstream door mat that could trap moisture and quite possibly cause an adverse reaction with the vinyl flooring.
anyone ever seen a generator like this? john hd Generators & Solar Power 35 08-05-2012 04:46 PM
Kool-matic vent - Anyone ever seen this??? SilverToy Roof Vents, Skylights & Fans 4 02-13-2010 04:05 PM
Has anyone seen this new Airstream? osp6179 Base Camp 22 10-04-2005 09:06 PM
Has anyone seen the "entertainment package"? Xray Our Community 0 02-28-2004 10:03 PM
Anyone seen anything like this? darkStar Our Community 22 08-01-2003 02:12 PM
