Old 01-06-2016, 11:52 AM   #1
1999 28' Excella
New Orleans , Louisiana
Anyone know an rv flooring installer?
We would love to change out our floating Alure floor with Coretec Plus plank? Thanks if you know anyone..we are full-timers so we would love someone in the S.
BadKat
badkat is offline   Reply With Quote
Old 01-06-2016, 12:00 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
A floor is a floor. Any home installer can do the job.
MICHAEL
Old 01-06-2016, 12:12 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Anything has to acclimate - reach the same temperature as the inside of the Airstream - and that normally takes a day, so you'll have to do a hotel for a day, not to mention empty out all of the lower cabinets. I had linoleum put into my Avion and that necessitated taking out some of the walls and furniture too. Some folks seem to be very happy with the click and lock planks, but many are NOT recommended for RV's. Some people have reported buckling or separation. Check all of your options carefully.
Paula
Old 01-06-2016, 04:15 PM   #4
1999 28' Excella
Great advice only I find that home installers will not remove the rv throne and put it back in place.
Will do some research and keep trying to get this done. Thanks
Old 01-07-2016, 10:24 AM   #5
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Where are you located?
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 01-07-2016, 11:38 AM   #6
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I have no personal experience of replacing a floor but follow the Long Long Honeymoon blog, and they had excellent service from Vinnies in CA:
Vinnie's Northbay Airstream Repair
See the video at:
Long Long Honeymoon | #Loloho » Search Results » floor
Old 01-07-2016, 02:10 PM   #7
2000 30' Excella
Monticello , Florida
Go to any store that sells flooring ask who they would recommend. After you have showed some interest in buying!
07007 is offline   Reply With Quote
Old 01-07-2016, 06:01 PM   #8
1996 25' Excella
Tillsonburg , Ontario
Biggest problem will be finding a good installer. We have laminate in our 25 that is standing up pretty well but it does show some swelling at the door way where water from shoes is in play. I have seen some terrible jobs on floating laminate floors where the installer allowed for movement but the short pieces at the walls shifted and left gaps over time. A bit of glue on the click joints will solve that problem. Good installers will make sure the minimum short length is 8 - 10 inches so there is less potential for the piece sliding way from the joint. You probably have 1/4 round all along the edges of your vinyl and that will need to be removed and replaced as the gap around the edges is needed to allow for thermal and moisture caused expansion. Original flooring in AS is installed before the cabinetry goes in so edges are clean, but replacement requires something to cover the edge of the new flooring, and doing a good job requires some extra scrap to make the edges stable.
JCW
JCWDCW is offline   Reply With Quote
Old 01-08-2016, 06:55 AM   #9
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Don't know your location, but we had our flooring replaced (seamless wood grain vinyl) at Ronnie Bock's Kerrville RV, in Kerrville, TX.
banderabob is offline   Reply With Quote
Old 01-11-2016, 07:38 AM   #10
1999 28' Excella
We are currently in Pensacola headed to N.O., on to College Station,TX then West.
Old 01-12-2016, 05:57 AM   #11
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
You might check with "Countryman's Marine and RV Repair" in Foley, Alabama. They have the capabilities, and the knowledge. The problem might be scheduling, they are extremely busy.....
Larry
Old 01-16-2016, 09:30 AM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm looking to get a new vinyl floor too. The CORetec Plus 5" floor looks promising. With he cork backing you don't have to worry about any imperfections with the subfloor according to the manufacturer. I would think if my cheap then OEM vinyl doesn't show any imperfections then the subfloor is already to go. Another note on the specs it say it doesn't expand or contract although the instructions still state to have 1/4" space to the walls. The wear layer is 20mil and its 8mm thick, locking planks, floating floor.Each box covers 26.6 sq ft which calculates to 16 5"x48" planks per box. Thinking 6 boxes may do my 25fb.
Products | 5" Plank | USFloors
Kelvin
Old 01-16-2016, 10:54 AM   #13
1999 28' Excella
This was also recommended to us. We are going to Bryan, TX end of February and found RV Source who will remove everything for the flooring guy to come to install on location. Fingers crossed..would love a new look in our AS.
Old 01-16-2016, 11:58 AM   #14
KJRitchie's Avatar
2008 25' Classic
What are you planning on having removed? We are in the process of getting bids for a twin bed conversion and floor. The local shop wants to take out the dinette, side lounge and queen then lay the floor down and build the twins over the floor. I think it would be better to build the twin frame over a bare subfloor and just lay the floor between the beds. This would save having to purchase so much flooring, labor and keep the weight down. They want to install quarter round along the hall walls.
Kelvin
Needed: ProPride Hitch installer in Texas (DFW Area) DallasTXJoe General Repair Forum 28 01-11-2014 08:16 PM
Best Solar installer in TX? wildwoodrver Generators & Solar Power 1 11-19-2009 11:47 AM
Looking for a Caravan awning tent installer sfmcdermott General Repair Forum 1 06-30-2009 03:30 AM
Need Installer for Motor fangthorpe Mechanics Corner - Engines, Transmission & More... 9 10-27-2004 11:48 AM
I bought an AS! now I need a carpet installer spinolio Airstream Motorhome Forums 0 05-01-2003 07:51 PM
