Old 01-17-2016, 06:42 AM   #15
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by Foiled Again View Post
I had linoleum put into my Avion and that necessitated taking out some of the walls and furniture too. Some folks seem to be very happy with the click and lock planks, but many are NOT recommended for RV's. Some people have reported buckling or separation. Check all of your options carefully.
Paula
None of the flooring from the major sources is recommended to be used in RV from what I can see. They all require conditioned spaces to honor any warranty and at least prevent failure. I suppose if you live in a temperate climate or full time its not as much an issue for someone that stores their AS over the winter in cold climates.
What brand of flooring did you have installed? Did the installation require removal of kitchen cabinets etc? It sounds you had a sheet product installed.
Kelvin
Old 01-17-2016, 06:51 AM   #16
1999 28' Excella
New Orleans , Louisiana
We are only removing the front side tables, sofa and toilet. CoretecPlus click and lock sounds like a wonderful floor but now my concern is weight. Guess that is the next thing to check out. Unless we have some hidden floor issues, which would be good to know that is all we are removing. Since we are full-timers, never store and stay in fairly moderate temps hope that will be enough.
badkat is offline   Reply With Quote
Old 01-17-2016, 07:41 AM   #17
KJRitchie's Avatar
2008 25' Classic
36.4lbs per carton.
8 mm thick
Using these numbers for their 5 x 48" plank
5 x 48 = 240 sq in
26.68 sq/ft x 144 sq/in = 3841.92 sq inches
3841.92 / 240 sq in = 16 planks per carton
5 x 16 = 80” wide = 7 foot 8” wide x 4ft long
For my 25fb figure about 6 cartons of material laid which would be about 218lbs roughly. This will probably be considerably heavier than the thin, paper back OEM vinyl.
This flooring is made in China.
Kelvin
Old 11-22-2016, 07:24 AM   #18
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Did you go with the Coretec?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Needed: ProPride Hitch installer in Texas (DFW Area) DallasTXJoe General Repair Forum 28 01-11-2014 08:16 PM
Best Solar installer in TX? wildwoodrver Generators & Solar Power 1 11-19-2009 11:47 AM
Looking for a Caravan awning tent installer sfmcdermott General Repair Forum 1 06-30-2009 03:30 AM
Need Installer for Motor fangthorpe Mechanics Corner - Engines, Transmission & More... 9 10-27-2004 11:48 AM
I bought an AS! now I need a carpet installer spinolio Airstream Motorhome Forums 0 05-01-2003 07:51 PM
