Old 06-19-2009, 05:40 AM   #15
Arlington , Massachusetts
I looked at the Nyloboard web site, but I couldn't find any information on weight or strength. It did say that sheathing has to be at least 1/2". It's not easy to replace the subfloor on an AS, and I'd rather only do it once. So I'd rather wait on Nyloboard to see how it fares over the span of a few decades.
Dismayed is offline   Reply With Quote
Old 06-19-2009, 06:00 AM   #16
Lothlorian's Avatar
Loganville , Georgia
My original sub floor was 3/4" thick. I went with 3/4" thick nyloboard. I took my grinder and gave the board a quick once over on the edge to help slide it under the Channel. It fit very well and tight.
After reading countless threads on rot in the bathrooms especially in the 70's airstreams I am very glad I went with the Nyloboard. My orginal floor in the rest of the airstream was in pretty good shape. I had a couple small rot spots I fixed with a product the historical society uses. It wasn't rot doctor. It turned those soft spots into very hard areas. It worked great. It soaked through the rot spot and killed the rot. It turned as hard as fiberglass. Then I used laminate on the the floor after I sealed the whole floor with Thompsons and Behr heavy duty stain.
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 07-13-2009, 01:02 AM   #17
CapnTom's Avatar
2004 30' Land Yacht 30 SL
St Petersburg , Florida
Images: 65
Send a message via Yahoo to CapnTom
Floor Replacement Shell Off 50 Liner
I just did a shell off floor replacement in my 50 Liner. It had a 5/8" floor but I opted for the 3/4" A/C fir for replacement. I sealed it with sanding sealer then primed the underside. I installed the boards gluing all the joints with the titebond exterior glue and made sure all the joint butts butted over the original double framed members. All the wood was securely fastened to the framing members and fish-bone framing. (a note here: this unit was an original pipe framed designed unit. But a PO had an a-frame installed forward of the steel axle assembly. So basically I have a ladder type unit 2/3rds the length of the trailer. This was a great find. The chassis is in great shape.) After securing the wood I then put new c-channel all the way around the perimeter. Originally it only had pieces of c-channel around the craved ends. I made these by using 2 L-channels. In addition to the C-channel I also installed an L-channel under the flooring around the perimeter upward as an edging and then used elevator bolts and fender washers every 8" to secure the C and L-channels to the new flooring. I felt this would give the floor to shell connect more strength. So basically when you rivet the shell back in place the rivets will go through the shell, belly pan, L-channel and c-channel.
No doubt this was a lot of work and if I had to do it again I'd still do a shell off replacement. It's the only way to go.
ID:	83837   Click image for larger version
Name:	5 - New floor installed.jpg
ID:	83839   Click image for larger version
Fair Winds and Following Seas,
But If You're Airstreaming let there be lots of Trees.
CapnTom
WBCCI/VAC #2453
AIR #35123
TCT
USAVTN
1950 Liner 22'
2004 Land Yacht 30 SL
2004 Chevy Avalanche
CapnTom is offline   Reply With Quote
Old 07-13-2009, 04:44 AM   #18
Lothlorian's Avatar
Wow! Those pics look great.
Nyloboard has technical data on their website. You just have to search for it. They will send you samples also.
Brian
Brian & Adrienne
Old 08-25-2009, 04:48 PM   #19
Portland , Oregon
The other thing I would recommend is a tiling substrate over the subfloor (if you're installing tile vs. a wood/pergo). Potentially, this could even save you the need to replace all of the subfloor, since it's waterproof.
You can even lay it directly over the existing flooring, so you donít have to spend time ripping out old flooring before laying tile. And, itís super thin, so it wonít raise the profile of the floor. Also, I guess this goes without saying, but it's super light.
Thereís tons more information here:
US Gypsum Company - Waterproofing membrane for ceramic tile installation
Full disclosure: I work with USG, but this seems like a good contribution to the discussion of subfloor in general.
JamieB is offline   Reply With Quote
alternative shell to subfloor to frame interface? benWa Repairing/Replacing Floor &/or Frame 2 01-07-2009 07:56 PM
Subfloor material dimension Ambie '64 Repairing/Replacing Floor &/or Frame 6 05-07-2008 05:00 PM
subfloor for dummies mudmuffin Repairing/Replacing Floor &/or Frame 12 08-02-2006 10:03 PM
Subfloor Repair Steve Heywood Repairing/Replacing Floor &/or Frame 2 01-13-2006 07:10 PM
No subfloor? Over59 Repairing/Replacing Floor &/or Frame 5 05-13-2004 06:41 PM
