Old 09-13-2008, 05:53 PM   #99
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by gc24 View Post
Anyone have any idea how many boxes of the Trafficmaster it would take for a 68 Safari 22'?
3-4 boxes
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 09-13-2008, 06:01 PM   #100
1967 28' Ambassador
1970 29' Ambassador
3-4 boxes
Steve & the crew
Old 09-13-2008, 09:30 PM   #101
pagosa springs , Colorado
Thanks, I appreciate that.
gc24 is offline   Reply With Quote
Old 09-27-2008, 08:55 AM   #102
2008 27' Classic FB
West Of Boston , Massachusetts
Tips on cutting around a round sink cabinet in a Safari 23?
I have read this thread and want to re-do my floor with the tiger wood.
I see no mention of cutting around the bottom of a "round" sink cabinet.
Any suggestion on a good method other than making a cardboard templet?
Thanks in advance,
Lin.
Life Is Not A Dress Rehearsal
"It's Okay to have too much fun"
New England Unit WBCCI 8701
TheThreeSeas is offline   Reply With Quote
Old 09-27-2008, 10:22 AM   #103
1973 31' Sovereign
Portland , Oregon
Images: 22
Thanks in advance,
Lin.
Making a template of some sort seems to me like the best way to do it. I think I would use stiff paper or thin poster board rather than corugated cardboard though. It would be easier to trim with scissors until it fits. Also it would be great if it were possible to slip your paper under the edge of the sink. You could then trace around the curve. Is there any chance that you can do that?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 09-27-2008, 10:33 AM   #104
2008 27' Classic FB
Poster Board
Malcolm
Malcolm,
I not sure on sliding under the sink but I don't see why not with time.
I like the idea of the poster board a lot easier than cardboard.
Lin.
Old 09-29-2008, 07:24 PM   #105
1973 31' Sovereign
Portland , Oregon
Images: 22
Malcolm,
Lin.
You are certainly welcome.
Malcolm
Old 02-06-2009, 08:32 AM   #106
I followed this thread for a while, and I'm not sure if it has been mentioned before, but yesterday I was in the big blue box, and it looks like they now also have a version of this vinyl planking, similar to the Trafficmaster Allure that can be found at the big orange box. I don't remember the brand name, and a quick search on their website didn't turn it up, but if you're looking into this type of floor, it appears there are now a couple of options.
I can't comment on its quality in absolute or relative terms, but thought I'd pass the information along.
Old 04-25-2009, 01:56 AM   #107
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
vinyl plank flooring options
It's called Novalis. We installed it in our house, because we have 3 dogs and needed something easy to clean and durable. Its great stuff, we've had it for about 4-5 years now and just needs swiffering or when I want to do a good clean I use my Hoover Floormate. We are going to be installing it in our AS soon also. We hate the carpet it has now. We have it in the golden oak color. Here is the companys site to see the options: NOVALIS. Lowes has a few options off the shelf, and the others can be special ordered. The off the shelf planks (4" x 36") run $0.98? each/sq.ft. I believe this is the same stuff that alot of Wal-mart stores have used in their stores (the 6" planks). It is very durable and looks just like wood at fraction of the price. In the house we used luan as an under-layment (primed), because our sub-floor had particle board over the floor joists, and it wouldn't adhere well the particle board according to the manufacturer info. In the AS we plan on just sanding the seams on our plywood subfloor, fill the bolt holes, then prime the plywood for good adhesion. I'll have to update after we complete the project within the next few weeks. Here's a pic of the house floor. The 1st one is the best image for the color, the second one shows the full hallway view.
Hope this helps.
Mary
ID:	79226   Click image for larger version
Maryw164 is offline   Reply With Quote
Old 04-25-2009, 08:46 AM   #108
Thanks Mary, I think it looks great in your house. After making my above post a couple of months ago, I did some more research on it, and found a pretty long thread about the Novalis product on the GardenWeb forums. The heavy majority of people who had installed it had very positive things to say, many of them having lived with it for several years as you have.
Like the Allure, I think it is well suited for an Airstream application. I went and picked up a couple of samples to see how it looks in the front half of my trailer, and I really like it.
Please do check back in with pictures once you have completed your trailer installation.
Old 05-02-2009, 08:16 PM   #109
1965 26' Overlander
1990 34' Excella
1975 20' Argosy 20
Upper Black Eddy , PA
I've been considering the use of Allure Trafficmaster in my AS MH. After doing an internet search, I found some interesting information. Apparently, Allure Trafficmaster CANNOT be installed in situations which are not climate controlled. In an environment which drops below 65 degrees, reports indicate that Trafficmaster seperates at that seams. The glue strips do not hold in situations with dramatic temperature swings.
I'm not sure about Novalis. If this is a complete glue down application versus a glue-together application like Trafficmaster--it may tolerate the temperature swings better. Not sure.
In other reports, folks have recommended Metro Floor from Konnecto-I think this is full glue-down application.
If anyone has tried Trafficmaster or Novalis in an AS, how are the results? Any problems with the temperature swings?
Kathleen
kdenault is offline   Reply With Quote
Old 05-02-2009, 09:29 PM   #110
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
We put down Allure last year fully knowing that they did not recommend it for trailers. We figured that if it didn't work well, we could always change it out in a few years.
The Allure was great for the first camping season, but I will confirm that when we visited the trailer during the winter, a lot of seams opened up due to the cold weather and shrinkage. They have mostly closed up now that it is getting warm again, but we did discover a buckling issue as it warmed back up. We had a fairly heavy chair on the floor and while the flooring could "pull" it when it got cold, it couldn't "push" it back when it started getting warm causing the floor to buckle. I removed the chair and put some weight (just a few throw rugs) over the buckled area. I guess when we get ready for the first trip of the year in a couple of weeks we'll remove the rugs and see if the buckle is gone (at least for this season).
Would we put down Allure in a trailer again? Probably not
Will we be living with it as is for a few years? Yes.
We do love the look and with the underlayment we put down it is nice to walk on, even in bare feet.
I will suggest that is you live in an area that does not freeze in the winter, Allure may not experience the same issues we have seen up here in the north, but it will shill shrink and grow a little with any temperature change. Leave a little room around the edges for this unless you are laying it at 100+F temperatures.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-02-2009, 09:43 PM   #111
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by kdenault View Post
"snip" In an environment which drops below 65 degrees, reports indicate that Trafficmaster seperates at that seams. The glue strips do not hold in situations with dramatic temperature swings."snip"
Kathleen
The installation instructions indicate 15 degrees to 95 degrees as the temperature range for using the product....?
Old 05-06-2009, 12:00 AM   #112
Maryw164's Avatar
1972 31' Sovereign
Checkout this new thread on peel & stick:
http://www.airforums.com/forums/f461...ick-51019.html
Cork Floor TowAir Floor Finishes 31 08-05-2011 11:01 AM
