Old 03-20-2014, 10:41 AM   #29
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I spoke to the manager of a local grocery store where they'd installed the Allure. They were ripping it out about 15 months after installing it.
It looked horrid about 1 year after installation, but the problem was a poorly prepared surface more than the product itself. The extreme amount of traffic on a commercial space didn't help either. What happened was that prior to installing this product they'd had normal 12x12" tiles put down with contact cement and the "cleanup" done when they removed them wasn't done properly. Little bits of adhesive were left along with a few gouge marks where the removal had been a bit too aggressive. After a while the heavy traffic flattened the vinyl so much that every little bump and dip showed through.
If you plan to use it, make sure the surface is smooth and clean. A tiny pebble will become visible as time goes by.
Paula
Old 07-27-2014, 04:57 PM   #30
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Name:	ImageUploadedByAirstream Forums1406501511.702753.jpg
My daughter & I are out camping right now & I thought I'd update the allure flooring debacle....It has expanded back quite a bit compared to what it was it was this spring. It's acceptable, since the care is so easy. Mine has a little bulge from expanding in one area, but I'm going to wait to address that until after we've gone through a winter with it installed.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-27-2014, 06:39 PM   #31
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I installed Allure (not the one with the glue strips) during December, last winter. The Allure with the "click and snap" assembly is much the same as most of the laminate flooring products, as it is a "floating" floor. Also, it's supposed to be waterproof. It's a lot easier to install than the laminate products.
So far, there has been no problems, as it can expand and contract with the temperature changes. This is the third AS that we've redone, if we do another, I think I'll use the same product again.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-27-2014, 07:25 PM   #32
Becky B.'s Avatar
1964 17' Bambi II
Good to hear, Larry. If I ever do another floor, I'll go with the click together kind you used.
Becky
1964 Bambi II
1988 Avion 32S
Old 07-27-2014, 07:31 PM   #33
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
This the same flooring that WalMart uses in the clothing areas of the store.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is online now   Reply With Quote
Old 07-28-2014, 01:54 PM   #34
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Nice!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-28-2014, 06:31 PM   #35
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Name:	ImageUploadedByAirstream Forums1406593705.951635.jpg
ID:	217689Click image for larger version
Name:	ImageUploadedByAirstream Forums1406593741.305793.jpg
We put it in and love the way it looks! Let's hope winter isn't to hard on it.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 07-29-2014, 10:20 AM   #36
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
Brad, I love the new floor. It looks great!
Nelson
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 07-29-2014, 06:46 PM   #37
blmitch5's Avatar
Olathe , Kansas
Thanks Nelson! I can't wait to see your 15 Classic. I may be Silver with envy!
WBCCI 4973
Old 09-01-2014, 07:30 PM   #38
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Here are some better photos of our 1986 excella bunkhouse. We are really happy with the allure flooring.
ID:	220537   Click image for larger version
Skatiero is offline   Reply With Quote
Old 01-18-2015, 10:17 PM   #39
WBCCI, Long Beach Unit
2003 31' Land Yacht 30
Costa Mesa , California
We're looking to replace ugly carpet in our 2003 30' Land Yacht MH. Love the Allure and appreciate all of the input in this thread. We're in So Cal and it sounds like it might be OK here, as we don't have the temperature extremes in many of the areas with not-so-happy users. Let me know if I'm mis-interpreting the input here... thx...
linda7915 is offline   Reply With Quote
Old 01-19-2015, 08:19 AM   #40
Ottawa , ON
Still happy, but still keeping fingers crossed
We put the sticky-edge Allure on about half of Henri's floor, directly on the plywood underlay. We went horizontal (across the trailer), our reasoning being that that way left shorter planks. We hoped that would mean less swelling or shrinkage.
It made it through last year's horribly cold weather perfectly, and we are hoping it will make it again. Here's a link to what the "cork" finished Allure looks like. I still love the look.
If you don't get to post #175 from that link, you will find it not far from the end of the thread. We are planning to finish the other half of the TT this spring.
Aage, still thinking that Allure is the way to go for flooring.
Old 02-01-2017, 07:09 PM   #41
Becky B.'s Avatar
1964 17' Bambi II
I thought I'd give an update on Allure Click Together flooring. I used this product in my Avion restoration instead of the sticky sided Allure flooring that I used in my previous Avion. That product had gaps due to shrinkage in the cold weather. So, I decided to use the click together because it couldn't let loose of the other side due to cold weather, right? WRONG! I was so careful to leave this floor absolutely floating. I trimmed it out and had nothing on top of it anywhere. Well, I went out there to look at it this morning & the ends have separated. Not only that, but I looked up the warranty for the flooring & it IS NOT RECOMMENDED FOR RV'S. So, take my advise if you have any cold weather in your area.....use sheet linoleum or sheet marmoleum or glue down something....just not Allure.... My son & his wife are at the point of picking out their flooring in their restoration & it won't be any Allure or snap together product.
Before Cold weather: Click image for larger version
During Cold Weather: Click image for larger version
Name:	flooring in cold weather ....ugh!.JPG
Becky
1964 Bambi II
1988 Avion 32S
Old 02-01-2017, 07:41 PM   #42
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
How cold?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Vinyl (we think) ceiling odor? Skater Upholstery, Blinds, Walls & Interior Finishes 14 07-27-2015 01:17 PM
New carpeting and vinyl plank flooring JMSx2 Land Yacht/Legacy Motorhomes 12 05-20-2014 05:09 AM
Wood Plank vinyl flooring wvabeer Land Yacht/Legacy Motorhomes 33 07-08-2013 05:13 PM
Allure Trafficmaster Vinyl Planks hippiechick Floor Finishes 53 06-09-2013 09:11 PM
Vinyl underlay Cauuck Floor Finishes 3 04-27-2011 01:26 PM
