Old 08-22-2013, 10:45 AM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Allure sticky side planks
Ok all, I have some allure planks. We are getting closer to installing it. I was Reading through the installation manual for the the flooring. It states not to use in a camping trailer. Since we bought it months ago returning it is not an option and we really do like the floor style.
Has anyone had problems with the heat during the summer on the floor? I was wondering if there's problems with separation or expansion issues. We live in Florida so the trailer does get very hot.
Silverflames is offline   Reply With Quote
Old 08-22-2013, 10:47 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I have Allure in my Overlander, had it in a Sovereign before. It expands a little in the summer but if you leave a 1/8 or 1/4" space around the edges it is fine. I cover the space with a shoe modling
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-22-2013, 10:58 AM   #3
1969 29' Ambassador
No buckling or popping up?
Old 08-22-2013, 11:13 AM   #4
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
My only input is I have used it in a couple of my rental properties. Great durable stuff and handsome as well.
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 08-22-2013, 11:39 AM   #5
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Silverflames...my experience hasn't been so positive. Installed Allure bamboo flooring in our "78" Ambassador. Left about 1/8" around the edges and ran it lengthwise in our Ambassador. It looked beautiful when first installed. That Winter we noticed considerable gaps in the flooring...more so end to end gaps. During the Summer some of the gaps close up with expansion. I'm in the process of flooring a "74" Tradewind and don't think I'll be using Allure but go with solid sheet flooring of some type...probably marmoleum.
Bob Leopold
Indiana, PA
PA TAC-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 08-22-2013, 02:16 PM   #6
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Silver flames,
We live in Texas and it gets H O T. I put the Allure in a 75 Argosy, run lengthwise. I did not leave enough gap at the edge and experience some buckling. Went back a trimmed to a 1/4" gap and problem solved. Love the stuff!!
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-22-2013, 02:19 PM   #7
1969 29' Ambassador
Originally Posted by bwoodtx View Post
Silver flames,
Good.. What was the temp when you laid the floor? I might want to adjust the temp inside to a middle ground so the seams don't expand and contract to much.
Old 08-22-2013, 02:28 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have used it too. It is great. Now....pay attention. When installing it use a pattern where you lay the sticky side down onto the previous piece. The adhesive is so good that if you touch the sticky strips at all...they are together. No adjustment. There is no sliding that one piece under the previous to a good connection. By laying it on top you have that control.
Old 08-22-2013, 03:06 PM   #9
1969 29' Ambassador
I'm sorry, in a but confused, I had my brain cell sucked dry at work today. What do you mean about a pattern? Like a card board cut out?
Old 08-22-2013, 03:20 PM   #10
Crusty's Avatar
1992 34' Excella
When I installed mine (which has been working fine for 4+ years now) I used the release paper laid onto the sticky surface to keep the two overlaps separated until I had the planks into position, then I kept them in place while I slid the paper out and bonded the overlaps. My gaps are really tight in the winter and less so in the summer, but I'm not that picky and I like the Allure flooring just fine. I left about a " gap around the perimeter with molding over the edge and it never buckles.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 08-22-2013, 04:06 PM   #11
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I have had ours installed for almost 2 years. Works great. I installed length wise. I used a cutter from home depot that was design to cut vinyl tiles. The cutter looks like a school paper cutter. Think carefully through your plan to minimize waste.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 08-22-2013, 05:26 PM   #12
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
I laid my floor in April and the temperatures were in the 80's when I did that.
Bruce
Old 08-27-2013, 02:10 PM   #13
1972 27' Overlander
Denver , North Carolina
2 Questions; what did you use to cut the curves? Did you start from the middle of the floor like most flooring or one of the edges? Thanks
mccrosti is offline   Reply With Quote
Old 08-28-2013, 07:47 AM   #14
Crusty's Avatar
1992 34' Excella
I laid mine out lengthwise cause I think it looks better that way. I snapped a chalk centerline on the floor and worked outward from it but understand that one side of the line is more difficult to lay when it's done that way because of the overlaps. I have a pair of really heavy duty shears and a razor knife that I used for trimming.
Crusty
Lake Travis, TX
"Rancho Deluxe"
