Old 08-28-2013, 08:23 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I made a template with heavy brown paper and cut the curves from that
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-28-2013, 08:33 AM   #16
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
My brother in law installs flooring for a living. He uses a heat gun to heat up the planks before cutting tight areas. You can also score the plank and then snap it.
Using heavy duty brown construction paper is a good idea. Use that to make your patterns, then over lay it on the planks you need to cut.
Install instructions state to start on one wall and then work your way over.
Silverflames is offline   Reply With Quote
Old 08-29-2013, 02:10 PM   #17
1972 27' Overlander
Denver , North Carolina
Thanks Guys, I like both ideas. I get some paper, make a story stick with a paint stick and figure the curves.
mccrosti is offline   Reply With Quote
Old 08-29-2013, 07:51 PM   #18
1969 29' Ambassador
Story stick?
Old 08-29-2013, 09:14 PM   #19
Tenkara Fly Angler
Big C's Avatar
1975 31' Sovereign
Vernon , Texas
We are in the process of looking. What we want is not good with Texas heat. Thanks for the thread!
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
Big C is offline   Reply With Quote
Old 08-30-2013, 02:18 PM   #20
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Did you check out the Ultra Allure with the interlocking edges? I think I'm going to try them. Not much about them here, but rv.net makes them sound promising.
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 09-07-2013, 06:09 PM   #21
1969 29' Ambassador
Ok got my Allure sticky sided floor installed. This is the African Dark Wood. Took about 6 hours with my wife. She is taking full credit for the work!
Bulkhead walls are next..
Old 09-09-2013, 04:49 AM   #22
1972 27' Overlander
Man that floor looks awesome!
Lucky Dave, Denver NC
Old 09-09-2013, 08:09 AM   #23
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have them in my galley area and they work great. They are waterproof. I ran a bead of sealant around the edges and then trimmed with quarter-round so that any spills are contained.
Place them VERY carefully. I used the paper separators from the boxes to keep the joints from touching prematurely. Once the adhesives touch, it is goodbye.
John W. Irwin
WBCCI #9632
Old 09-09-2013, 08:18 AM   #24
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by Silverflames View Post
Story stick?
You're done for this project but file this away for future use. Handy and simple for making templates of curves -- Story Stick thread
5 meter Langford Nahanni
Old 09-09-2013, 08:31 AM   #25
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Beautiful! Just curious: how heavy is it? We probably added close to 500lb to our trailer weight with our floating cork floor. Worth it, but something to keep in mind.
Kay
Old 09-09-2013, 09:27 AM   #26
1969 29' Ambassador
I would say each case is close to 50 lbs each. It took 7 cases, so close to 350 lbs. They are very dense, heavy, but easy to install.
Old 12-08-2013, 06:18 PM   #27
Cyberous's Avatar
1995 21' Sovereign
Hollister , California
What did all of you use as a flexible quarter round?
Our 25FB has lots of rounder corners on the cabinets and bed so we need something that will follow the curve.
Cyberous is offline   Reply With Quote
Old 12-08-2013, 09:45 PM   #28
1969 29' Ambassador
We have not gotten that far yet, but here is a option.
http://www.amazon.com/gp/aw/d/B006R9...dir_mdp_mobile
