The floor has worked out great for us, 1/8" easy installation, no smell after install, different look, VERY durable, wipes clean. Things to consider, the rubber is kinda cold to the touch (we use rugs in high traffic areas), liquid will run through it if you spill something big...though not fast like a screen!, dont use too much glue as it does push up through the floor when you roll it (easy clean up). We're a year into it & still very happy going with the rubber. When you are looking for it, I bought mine direct from Ecosurfaces because they are local & I could pick up, ask about roll ends. I bough a roll end & it was WAY cheaper then buying the roll. For being recycled (to me USED tires) the stuff is not cheap!
http://ecosurfaces.com/
