Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 11-03-2002, 12:28 PM   #1
Profile:
What shocks?
Please help me resolve the conflicting advice on the forum re: appropriate shocks.
RJ's great site on restoration of his 65 Caravel indicates he used Monroe shocks for the front of a 1960-67 Chevy PU (Napa pn 94005)
Andy posted that "The "Airstream" shock absorber is now made by Gabriel. It is a horizontal shock. A vertical shock will not work properly as a replacement."
What is the difference between a horizontal shock mounted vertically and a vertical shock? The Napa shocks are available locally. What is the performance difference?
Any advice on how to get them compressed the 3 or 4 inches necessary to get them on the frame?
Thanks!
Silver Annie is offline   Reply With Quote
Old 11-03-2002, 02:14 PM   #2
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
compress the shock to the desired length by hand, then have a helper either wire or tie some string from one end to the other. (try to get it around the eyes on the end not through them)
then you can install the shock, get the bolts or nuts started then cut the string/wire.
as for the differance between horz. and vert. i'm not sure, but i'd bet it has to do with the internal valves.
john
john hd is online now   Reply With Quote
Old 11-03-2002, 02:55 PM   #3
Profile:  LOST , Hawaii
Valving and the reservoir. Think of a gas tank on a car, pretty flat with the pickup in the center and reaching the bottom. Turn it on end and you will only get half the gas out because the pickup now is halfway up the tank. Basically the same reason a vertical shock won't work in a horizontal position.
John
74Argosy24MH is offline   Reply With Quote
Old 11-03-2002, 05:13 PM   #4
Profile:
Well, the current shocks ARE mounted vertically. I guess that means that for the 65 Caravel, the Monroe shocks listed by RJ should work better than the horizontal Airstream/Gabriel shock...?
Old 11-03-2002, 06:00 PM   #5
Check with NAPA and see if that # shock is a horizontal or vertical mount.
John
Old 11-03-2002, 10:38 PM   #6
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Shocking isn't it!
Annie,
There are but a hand full of shock manufacturers nation wide. They will make a shock to any spec that you want as long as you purchase enough quanity. You can then put your label on it and sell it as yours. That being said ..... if you have a vertical shock then these should work.
NAPA # 94005
Monroe # 30033
>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is online now   Reply With Quote
Old 11-04-2002, 12:14 AM   #7
68 Suburban's Avatar
Profile:
I am looking for 4 monroe shocks #18949. Any leads? Thanks
Here is the link to Dingo's trailer:
1968 Avion T-22
68 Suburban is offline   Reply With Quote
X-Ref on shocks? RonJudi Mechanics Corner - Engines, Transmission & More... 4 03-18-2004 08:02 AM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 01:45 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 09:16 PM
installation of shocks TCP4 Shocks 1 05-02-2002 05:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 11:13 AM
