Old 05-13-2014, 09:33 AM   #1
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Vertical mounted shocks ?
Hi All,
Our newly purchased 1966, 28' International Ambassador Landyacht needs new shocks. The shocks look to be "rusted original" and are vertical mounted. Is this correct for the 1966 ? Everything I've read so far on the forum says "horizontal"
mounted shocks. I don't see signs of any modifications so I'm assuming vertical mounted shocks were stock for this vintage ? Does anyone have a part # for my needed shocks ?
Thanks for your help,
Danny
Danny Bell is offline   Reply With Quote
Old 05-13-2014, 09:47 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Not sure when they went horizontal but my 61 has vertical shocks
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-13-2014, 10:27 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The modern Airstream shocks will work vertically. Our '63 had Monroe shocks, but the numbers were so rusty it was impossible to read them
Old 05-13-2014, 11:10 AM   #4
Originally Posted by Danny Bell View Post
Hi All,
Danny
Danny.
Vertical shocks were used on the 1968 models and older.
The 1969 and newer models, to this day, use horizontal shocks.
Airstreams horizontal shocks work equally well when positioned vertical.
However, the distance between the two shock studs must not be greater than 14.5 inches.
If it is greater, then cut the vertical bracket in half, over lap it and weld it back together, so that the distance is no more than 14.5 inches between the studs.
Or, mount new studs on the frame, duplicating the new style.
Old 05-13-2014, 03:26 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Or you can use non-Airstream shocks on vertical installations.There are many choices. I used a non-Airstream shocks with great results on my '66 Overlander. Knowing the mounting types and the compressed and extend dimension is all that is needed for many supply houses fpr shocks.
<>>>>>>>>>>>>>Action
Shocks or no shocks? Thisisliving Shocks 34 07-01-2013 08:59 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
Vertical shocks Scott S Shocks 2 05-31-2008 09:53 PM
