11-16-2016, 05:38 PM
2012 25' FB Eddie Bauer
laguna beach
Shocks on 2012 Eddie Bauer 25'
My mechanic is going thru my AS, just told me shocks are toast and I need to replace them. They are Gabriel 610816. I would like to put a better quality shock on, preferably bilstein.
Has anyone else done this, any thoughts?!? Thanks in advance...
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
11-17-2016, 08:29 AM
Vintage Kin
Fort Worth
Shock absorber design can be pretty specific. Torsion axle AS trailers are one of those places. Personally, I'd doubt shocks 4/5 years old have failed unless can be shown seals blown and fluid leakage. See other threads on this site. Andy at Inland RV for info search words, and purchases
1990 35' Silver Streak
2004 555 Cummins
11-17-2016, 10:57 AM
2012 25' Flying Cloud
Battle Lake
I wonder how he mechanic determined the shocks were toast? Road test, leaking, did he pull them? Have things been thrown around in your Airstream going down the road?
We have a 2012 FC 25 with Michelin 16" tires and had the running gear inspected, bearing runout and brakes checked, tires rotated last spring at Jackson Center. I talked to the mechanic, he said all is in excellent condition. Never mentioned shocks specifically as I recall.
Doug and Cheryl
11-17-2016, 12:11 PM
Moderator dude
1966 26' Overlander
Phoenix
Those shocks are mounted more or less horizontal. (Different than vertical mounting) Because of that the oil & valves in a horizontal mounted shock is in a different position. Mounting a vertical shock in a horizontal position doesn't work.
Because of limited application only Airstream supplies the correct shock.
>>>>>>>>>>>>Action
11-17-2016, 07:15 PM
laguna beach
The seals are blown, somfar I haven't been able to find anything available except the Gabriel's which, according to AS is a specific shock made exclusively for them...
11-18-2016, 09:13 AM
Vintage Kin
Fort Worth
By report, the AS-specific shock absorbers are inexpensive.
2004 555 Cummins
11-18-2016, 11:18 AM
2006 19' Safari
East Greenbush
, New York
They're available from any AS dealer, and online at Outdoors Mart and Inland RV.
Not very expensive at all. And you're right, Gabriel custom makes them for AS.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
11-18-2016, 01:01 PM
Diehard51
1986 25' Sovereign
Bulverde
Sparkymark,
I just received 4ea AS shocks for my 1986 Sovereign 25' They are Gabriel brand purchase from Inland RV, there p/n 12416, they are currently on sale 25% off at $30.00 each. Great customer service and fast shipping.
Mike
12-17-2016, 04:36 PM
laguna beach
Update: so, all 4 were absolutely shot-if your mechanic doesn't remove the shocks to test them-then they didn't test them. I found a similar replacement made by Bilstien and they all have been replaced and work perfectly!!!
12-17-2016, 05:17 PM
2017 23' International
Curry County
, Oregon
I too have a 25' Eddie Bauer. Just wondering how many miles do you think you have on your trailer before you replaced your shocks?
12-18-2016, 10:49 AM
laguna beach
I purchased it as 'previously owned' in 2013, have no idea of mileage before I picked it up...I purchased it in Arkansas, probably around 5-6,000 over the last 3 years. Not a lot of miles.
12-18-2016, 05:48 PM
Curry County
, Oregon
Hmmm! I failed to mention mine is a 2012 as well. I probably have about 7 or 8 thousand on mine. I guess I better go get mine checked. Thanks for the reply.
07-06-2018, 08:23 PM
2009 25' FB Classic
Scottsdale
Wow we have a 2009 25FB Classic with over 30,000 miles no problems with shocks.
Bob & Julie # 5587, 4CU in AZ
07-06-2018, 09:53 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Do you happen to have the Bilstien part number of the shock you used?
07-07-2018, 11:32 AM
2016 27' International
Sherwood Park
, Alberta
2 1/2 year old thread. Not sure you will get an answer.
07-07-2018, 11:59 AM
Moderator dude
1966 26' Overlander
Phoenix
If it were me, I would reach out to Bilstien and ask them if any of their shocks would work mounted in a horizontal position.
>>>>>>>>>>>Action
