Old 08-04-2015, 06:35 AM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Shocks for 89 34' Limited
What is the correct shock for an 89 Limited 34' ?
Will the 555-003 monroe shocks work ? Alternative ?
thanks
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 08-04-2015, 08:34 AM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Airstream trailer shocks are specific. Contact a dealer or Inland RV.
Old 08-04-2015, 09:31 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
To expand on that .....Airstream shocks are mounted in a more or less horizontal position and are designed to work in that position. All other shocks are mounted and designed for opperatioin in a vertical position. Mounting a shock designed for vertiacl opperatioin in a horizontal position means the shock will no longer perform the task as the oil inside the shock is no longed in position to dampen movement relative to the valving inside the shock.
This mounting arrangement was created in 1967 to reduce the space needed for running gear inside the coach.
Airstream or it's dealers are the only source for these shocks.
>>>>>>>>>>Action
Old 08-04-2015, 10:22 AM   #4
submariner's Avatar
1948 22' Liner
1989 34' Limited
I would see that to be correct on oil shocks, but I hear a lot of people using the Monroe RV Gas shocks . Gas don't care about direction .. Just a thought ?
Stefan
Old 08-04-2015, 11:45 AM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
IF the gas-charged Monroe RV shocks can be used, I can post a link to a place that had an awesome price on them.... but I'll wait to hear from Airstream-knowledgable people.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 08-04-2015, 12:37 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The gas charge is not in place of oil it is in addition to oil. And the gas shock may have a force that is greater than the shock bracket can handle.
Contact a knowledgable shock retailer and as them if the shock will work in a horizontal manner. Or ask them if you can return the shock after installation. you may not knwo after installation of a gas shock if it is working as the gas charge will always have pressure in resitance .
Or ask your local Airstream dealer if you can use any shock for a horizontal installation.
>>>>>>>>>Action
Old 08-04-2015, 01:03 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
MONROE SHOCKS & STRUTS :: Technical Training :: Shock Absorbers
For your review.
>>>>>>>>>>>>>>>>Action
Old 08-04-2015, 02:37 PM   #8
submariner's Avatar
1948 22' Liner
1989 34' Limited
thanks for the info
Stefan
Old 08-04-2015, 03:28 PM   #9
Shocks
Airstream shocks, since mid 1968 models, are horizontal. However, they work vertically equally well.
Vertical shocks, of any kind, will not work horizontally.
The current price of Airstream shocks from some parts stocking dealers, is much less that many vertical shocks.
Also, we have had numerous reports from customers that used the Monroe gas shocks, that they experienced shearing of some of their shock studs.
Why in the world, someone is looking for a substitute for the cheap Airstream shocks, is a HUGE mystery, AND a big gamble.
Save yourself from possible damage to your Airstream, and use the shocks that Airstream has been using for over 48 years, with zero problems.
Old 08-04-2015, 07:29 PM   #10
submariner's Avatar
1948 22' Liner
1989 34' Limited
Thanks Andy, did not know they had come down in price that much.. Thought the oem were higher :-)
Stefan
Shocks or no shocks? Thisisliving Shocks 34 07-01-2013 08:59 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
