Originally Posted by tredding
Does anyone know what shocks to use on my 63? Do the 63s use the same as 69?
From mid
1968 to the present, Airstream used a "horizontal shock".
Prior to that vertical shocks were used.
However, horizontal shocks will work vertically.
You can cut the vertical bracket in half, reweld it so that there is a maximum of 14.5 inches between the shock studs using a good axle.
The, you can forever use the special Airstream shocks.
They are not expensive.
