Old 08-15-2003, 07:21 PM   #1
Send a message via Yahoo to air66caravel
shocks
Went to replace the shocks on my '66 caravel today and one of the lower bolts twisted off due to rust. Any thoughts on replacing it. Looks like the head of the bolt may be welded into place, but hard to tell due to the rust that is present. Thanks for any thoughts you may have! Brad
air66caravel is offline   Reply With Quote
Old 08-15-2003, 07:56 PM   #2
Send a message via Yahoo to Fun-Lovin
Its really hard to say without seeing what you have.
You may have to use a cutting torch or a welder to get it fixed.
Post a picture and I may be able to give you an idea of how I would approach your problem.
Greg
Fun-Lovin is offline   Reply With Quote
Old 08-15-2003, 09:33 PM   #3
Chas's Avatar
Images: 22
If you can get at it you may be able to grind the remainder of the broken stud off, redrill the hole and put an automotive shock stud back in it's place. The only thing is it may have a welded attachment due to clearance issues, there might be no room for a threaded stud mount.
Chas
Chas is offline   Reply With Quote
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 08:16 PM
installation of shocks TCP4 Shocks 1 05-02-2002 04:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
