Old 07-11-2003, 10:09 AM   #1
Al1
shocks
Have 1973 24" Argosy.
Does the shocks functional value to the suspension system merit their replacement and if so how? Does the entire axle have to be removed to do so?
Thanks again for any help or suggestions.
Al1
Al1 is offline   Reply With Quote
Old 07-11-2003, 01:21 PM   #2
Chas's Avatar
Images: 22
The shocks supposedly dampen the oscillations of the axle, much like the springs on your car. There has been some debate on their effectiveness and in fact some of the newer model Airstreams don't even have them. The rubberset rod in a tube Duratorque axles do behave differently than your usual leaf and coil spring suspensions so that may be the reason for the difference in opinions. If you have them original from the factory you might as well keep them. They aren't too bad to change, but there can be some interference with reattaching the new ones due to their bolting locations close proximity to the frame. Usually a bit of coaching with a pry bar will get you enough clearance to get the new one on. The old ones had split rubber bushings which made them easier to replace but no more, solid rubber seems to be the norm. They are also a special application due the almost horizontal position and require special internal valving.
Good Luck my friend!!
Chas
Chas is offline   Reply With Quote
« Shock time | Top | shocks »
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 08:16 PM
installation of shocks TCP4 Shocks 1 05-02-2002 04:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
