Old 08-28-2007, 12:50 PM   #15
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Use a nut splitter........
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-28-2007, 01:43 PM   #16
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
nut splitter?original nut has a welded flat washer on itThis Shock replacement job,is a real nut buster,
wbcci ,#3510 NEU & 4cu http://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 08-28-2007, 02:11 PM   #17
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Rivet Nut jammed on frame .
A/S must have put the shocks on before they attached the axel to the frame,Now the only way to get shock off is to bend the metal plate in front of the schock to get it off,fun day working on this.Maybe I should have sent it to the dealer for schock replacements.
Old 08-28-2007, 02:55 PM   #18
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Shock out
Definitely will have to bend that thick steel plate to get new shock on,heres the old shock with split rubber gromet and the striped nuts .New case harden nut and washer on right 1/2 inch nut and wasker cost 1.00 one down 3 to go.for another day.
Name:	P1040248 (Small).JPG
Old 08-28-2007, 04:36 PM   #19
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Hey John....Good job..sounds like that was quite the project. I learned something new from this thread. I had to look up what a nut splitter was...never heard of one. Now I have to get me one! Looks like they would come in pretty handy! Good luck getting the other 3 off...How did you end up getting that stripped nut off? I usually use a box wrench and a hammer and some PB Blast for the buggers
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 08-28-2007, 04:59 PM   #20
The shock brackets can easily be bent to allow the shocks to go on and off with ease.
Once they are bent, leave them in that position, as it will not hurt the operation of the shocks.
Old 08-28-2007, 05:41 PM   #21
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
THANKS MARY ,ITS A VERY TIGHT SPOT 15 YEARS A RUST ORIGINAL NUTS.A TOUGH JOB, NOT AS EASY AS ANDY SAID IT WAS.i USED PB BLASTER A PIPE WENCH AND VISE GRIPESFYI NUT SPLITTER WILL NOT WORK ON THIS TYPE OF NUT, IT HAS A WASHER WELDED TO IT.FLUSH WITH SCHOCK.
Old 08-30-2007, 12:34 PM   #22
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Thumbs up Shock Replacement
Hi Andy,you were right,it takes less time,if you do it right.I did not first bend the plates that hold the top shocks on.This step makes it earier so as not to strip the top nuts.Also moving both wheels makes the acessablilty for getting the pry bar in to bend the plates and make it easier put the shocks on and tighten the nuts.You can see I treated the beam with rust prove paint.The otherside should go very fast now that I have it down.Yes a six pack for each side. is about right.
Name:	P1040249 (Small).JPG
Old 08-30-2007, 01:09 PM   #23
Was that a six pack per side, or per wheel?
Old 08-30-2007, 01:14 PM   #24
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
Mixing Shocks
Andy I have a question on the Shocks.I installed 2 types.of shocks both from airstream in Ohio.I had a old pair that is 10 years old never used A/S .From the previous owner.they are Delco part # 4975425 a heaver shock from 10 years ago.Installed them on the front axel.The second shock is also a A/S shock a Gabriell part #1700312SA it matches the original shocks replaced.you think I am ok doing this.Thanks John. Pss.The top shock is the Delco and bottom shock is the Gabriell.
Name:	P1040253 (Small).JPG
Old 08-30-2007, 03:43 PM   #25
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
per side lolol I am a slow drinker.
Old 08-30-2007, 04:04 PM   #26
Internally, the shocks are the same.
Old 08-31-2007, 12:33 PM   #27
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
all done 1 side
I even, ajusted my breaks and painted my rims and clear coated them .Have a look .
Name:	P1040256 (Small).JPG
Old 08-31-2007, 12:37 PM   #28
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
Looks awesome - Wayne would approve.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Atwood Question ALANSD Water Heaters, Filters & Pumps 2 04-14-2004 09:54 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
