Old 04-01-2005, 10:40 AM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
SHOCKing question......
Let me start of saying I am not a mechanic and I have never played one on TV
I got my new Gabriel shocks in the other day. I assumed they would be extended and that I would have to compress them during the install to fit on the mounting bolts.
But they are in the compressed state so they would have to be pulled apart to mount. I tried pulling them and couldn't really do it. I didn't try really hard though. So how does this work?
I know its a dumb question but I had to ask....
-Tim
theVAP - Airstream Podcast
Old 04-01-2005, 10:48 AM   #2
New Borockton , Alabama
Images: 21
Tim,
I replaced mine a couple years ago. Just pull them apart to the correct length and mount 'em. They are gas and designed to work somewhat horizontally. The trick is to get the bolts off without breaking them. Several soakings with liquid wrench and some beers in-between will help.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 04-01-2005, 10:55 AM   #3
Images: 59
All the gas filled shocks I've seen have a nylon strap and are shipped in the compressed condition. If yours are not gas filled, they are probably just stuck in the compressed condition and will pull apart with a little arm power.
If they are gas shocks, be sure the nylon strap is cut. I like to use iron wire to hold them partially compressed during installation.
Old 04-01-2005, 11:14 AM   #4
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I tend to over think stuff so I don't break something. So I'm usually more annoying than harmful ;-)
Just use more arm power and less brain power ;-)
Thanks.
-Tim
Old 04-01-2005, 01:49 PM   #5
I would like to know where I can get the replacement shocks?
Mine would have to be about the same as Tim's. Our trailers are not that far apart in age.
I know Inland carries them but I recently changed my opinion about the company.
Are there any other choices out there?
Anon is offline   Reply With Quote
Old 04-01-2005, 01:56 PM   #6
Elgin , Texas
Images: 164
Hey Lou,
Monroe and Napa both make a shock that many have used as direct replacements to the originals. Quick search on here should reveal part numbers, plus the folks who used 'em.
bake315 is offline   Reply With Quote
Old 04-01-2005, 02:06 PM   #7
Originally Posted by coriolis1
Hey Lou,
Thanks, Dave!
By the way, YOU ROCK!
Old 04-01-2005, 02:11 PM   #8
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Yes there are alternatives!
I did not buy from Inland because of the dealings I have had in the past.
I purchased my shocks from oasisrv.com for about $34 each. They shipped them quickly and charged less than $10 shipping.
-Tim
Old 04-01-2005, 02:41 PM   #9
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Delco was supplying shocks in '67. Here's the thread where I posted part numbers.
Tom
Old 04-01-2005, 08:59 PM   #10
LLB21's Avatar
I've had good luck with C&G Trailer. Website is www.CGTrailer.com.
They have been recommended to me by many during my travels.
Louie
LLB21 is offline   Reply With Quote
Old 04-01-2005, 11:05 PM   #11
Images: 21
My parents had their Airstream serviced, repaired and maintained by C&G for years with no complaints. I don't live in SOCAL anymore but I always stop buy when I'm there. Friendly honest people.
888-828-1893
Bestconverter.com
Old 04-02-2005, 12:12 AM   #12
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I would recommend against using gas shocks on an Airstream trailer.
They are usually too stiff for the application on these trailers. The bracketry is not designed to support this kind of gas charged shock.
The Torsion axles benefit from a passive, hydraulic shock that merely dampens the movement of the torsion arm. Most gas shocks have a substantial pre-load, which in my opinion would not be beneficial in an Airstream suspension.
I tried Napa for their shocks, and was told that they only sell gas shocks now. Besides, their prices are just slightly less than the shocks from Airstream.
Uwe
www.area63productions.com
Old 04-02-2005, 03:14 AM   #13
TomW's Avatar
1967 26' Overlander
Hmm, the link appears to have gone bad.
Let's try that again:
http://www.airforums.com/forum...ad.php?t=12716
Tom
Old 04-02-2005, 10:57 AM   #14
Images: 21
Uwe,
I thought the Gabrielís WERE gas. I know they are supposedly "Special" but I always questioned how "special" they really were since the part number crossed over to NAPA. The Gabrielís are readily available from any Airstream dealer so I never bothered to chase down the other brands.
Another note on installation, I had to bend the bracket to get the buggers off but it pounded right back and doesnít appear to have weakened the bracket.
888-828-1893
Bestconverter.com
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
