Old 04-28-2010, 03:02 PM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Shocking!!
Crawled under the trailer today to determine how much work it will be to install the new shocks. PLEASE TELL ME I DON'T HAVE TO DROP THE AXLES TO INSTALL THE SHOCKS! I can't see that there is enough clearance between the end of the stud and the frame on the axle end of the shock to slide the shock off. What am I missing?
Old 04-28-2010, 03:06 PM   #2
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
You got it. There is not enough room. To replace them you will have to bend the stud to get them off andthen bend it back when the new one is installed.
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
Old 04-28-2010, 03:14 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
I mounted the shocks on the axles before installing new axles...but of course that doesn't help you...
I think I've read that you can make one cut in the rubber bushings - a radius like cut so that it's possible to install them onto the shock after the shock is remounted on the stud...
In other words, without the rubber bushings, it's possible to move the shock around at an extreme angle to get it onto the stud - then because the bushings have been cut, twist them over the stud and into place on the shock - inside and out...
When the washer and bolt have been tightened on the stud, the cut bushings work as just fine as they are contained in place - I'd rotate the 'cut' portion of the bushings 90 degrees to the action of the shocks...
I haven't tried this method, only have read about it...
Ray
Ray & Pat; Morada, CA
Old 04-28-2010, 03:21 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The original shocks have a split 2 piece rubber bushing. ( or did in 1969) Perhaps you can either push out the new bushing which I assume must be one piece on the new shock? either cut it as a 2 piece bushing or reuse the old one. Been a number of years since I did this but I was able to do it with out dropping the axle. Probably some one will chime in with more up to date info
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-28-2010, 05:36 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The shock bushings on our '83 Excella are cone shaped, with the small part of the cones coming together inside the shock mounting ring. By removing the nut and washer, removing the first cone, twisting the shock downward or upward, the shock should come loose from the remaining cone shaped bushing, and slide out above or below the mounting stud. Make sure the bushing is not still stuck inside the ring. More easily done with the wheel removed.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-28-2010, 06:22 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Duh!!
I wonder who the rocket scientist was that designed this system?
Old 04-28-2010, 06:35 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would be interested to know if it works for you.
Old 04-28-2010, 06:38 PM   #8
1989 32' Excella
Limestone , Alabama
As I recall, when replacing shocks, the old shock required a bit of twisting and pulling to compress the rubber and allow the shock to come off the mount, but I didn't have to bend the mounting stud. For the new shocks, I removed the rubber bushing and cut it in half as Mexray describes in his post. Them one half is installed in the shock, the shock installed on the mount with by twisting it a bit, then the second half was installed followed by the washer and the nut that holds it all together.
Hope this helps!
Steve
war eagle is offline   Reply With Quote
Old 04-28-2010, 08:27 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Well it's them there Airstream ingineers that never tried using the trailers they designed
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-28-2010, 09:11 PM   #10
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Here is a video showing how it is done.
Airstream Shock replacement guide
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 04-28-2010, 11:25 PM   #11
Maniacal Engineer
barts's Avatar
Menlo Park , California
If they would not weld that shock mounting stud into the bracket on the axle, but make it bolt on instead this would be a lot easier, and only marginally more expensive. The same trick could be used for the mounting stud at the other end of the shock, so when it rusted up you could cut it off and replace it w/o a welder....
BTW - tip for getting those rusted nuts off easily - a really good penetrating oil can be made at home w/ 75% acetone and 25% ATF or other light oil; the acetone makes this stuff work really well and it simply races into small spaces. Naturally, keep it away from plastics you want to keep....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-29-2010, 11:45 AM   #12
lynn's Avatar
I would imagine Wally Byam
lynn is offline   Reply With Quote
SHOCKING ... or maybe not FreshAir Generators & Solar Power 22 09-27-2008 10:19 PM
Shocking Question firedog Shocks 33 09-01-2007 05:42 PM
A shocking story mandolindave Off Topic Forum 21 08-06-2007 08:28 PM
Need shocking advise! eikel1we Shocks 9 10-01-2006 02:30 PM
SHOCKing question...... Safari Tim Shocks 27 05-17-2005 07:50 AM
