Old 03-07-2003, 05:11 PM   #1
Shock time
This is just an update on shock replacement. After reading all the threads about this subject, I bit the bullet and had a go at it. I ordered four new shocks for our 32 year old Safari from Andy because I knew they would be the right ones. Removed the tires and took them to be balanced. Put penetrating oil on the bolts. Bent the brackets with a big crowbar just like an earlier thread had suggested. Removed the nuts and washers and then replace the old shocks with the new ones. Worked like a dream. Plus, it was a nice sunny day in the high 60's here in Tennessee. Life is good. Now, ready to hit the road.
Dan
Dbraw is offline   Reply With Quote
Old 03-07-2003, 05:16 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Dan,
As far as I can tell my shocks are in good shape but when they need replacement, do you make housecalls?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-08-2003, 06:52 AM   #3
House Calls
Craig,
Yes, I do make house calls. However, the food and mileage will really get into your pocketbook. Estimated work time would be: No beer- two hours. With beer-fourteen days.
Dan
Old 03-08-2003, 07:18 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Dan,
Where those the orig shocks? Can you or anyone tell me what the average life of the shocks should be on the A/S?
Eric
Old 03-08-2003, 03:40 PM   #5
Eric,
Yes, they appeared to be the original shocks. They were quite loose and easy to extend and retract. I don't know what the life of shocks are. However, since trailers don't get used as much as tow vehicles, I would thing they would last quite a long time. Possibly 5 to 8 years or more.
Dan
Old 03-08-2003, 04:04 PM   #6
Aluminut
2004 25' Safari
. , Illinois
Thanks for the info Dan.
Regards,
Eric
« What shocks? | Top | shocks »
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 06:15 PM
Attention: Driveway Campers _ time to hit the road ! femuse Our Community 5 04-04-2003 12:01 AM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 08:41 AM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
