Old 03-29-2010, 10:13 PM   #1
sound-silver's Avatar
1978 29' Ambassador
2004 25' International CCD
Moab , Utah
Shock replacement time?
We've had the 04 25' CCD for about 2 years. It's probably had 45K of tow miles with us. Recently a tire got all chopped up like when they do when a shock is worn out (like on my cars when I was younger). I replaced the tire and then noticed that another tire is developing the same condition.
It can also maybe be brake lock or balancing, but the tires are all fairly new and should be balanced.
I'm pretty sure it's the shocks, but I want some input if some of you think this is what it is too.
I have learned on this forum that I would need the Airstream horizontal shocks made by Gabriel if that is indeed the problem.
It's not where you are, but your reason for being there.
sound-silver is offline   Reply With Quote
Old 03-30-2010, 12:01 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if your trailer has drum brakes, balancing the tire/wheels is almost useless. The drums are not balanced so it will always be out. I, for one, installed Centramatics to cover for the drums even though my tires/wheels are also balanced. Check out the threads on balancing your running gear, or Centramatics. [there are other choices too] You may, or may not, need shocks, but it sounds more like a balance problem to me.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-30-2010, 07:39 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I am not convinced your shocks are causing the tire wear issue. Howvere it is time to replace them. (6 years and 45000 miles.)
>>>>>>>>>>>Acton
Old 03-30-2010, 08:43 AM   #4
I have a 2004 Safari with about the same mileage.
Modern gas filled shock abosorbers should last longer than 45,000 miles. Any ideas about how to tell when they are wearing out?
Mine have no leaks or other signs of wear.
Uneven tire wear or cupping sounds like a balance or alignment issue.
handn is offline   Reply With Quote
Old 03-30-2010, 08:51 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Does sound like an alignment issue or balance. Pull the wheels and or crawl under the unit and look for lead weights on the rims if your not sure if they have been balanced. Check the shocks by taking off them off and testing how much resistance is there after you pull the rod all the way out and then trying to push the piston back in.If you dont see any oil around the shaft or on the shock body U should be good.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-30-2010, 09:57 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Gas shocks will not work in a horizontal postion. Only verticle like a car or truck.
>>>>>>>>>>>>>Action
Old 03-30-2010, 05:38 PM   #7
1978 29' Ambassador
Moab , Utah
I ordered some Dynabeads today. They seem like a great simple solution to balancing issues. If it all works out I'll probably switch to Centramatics when this set of tires wears out.
There's quite a lot to learn about taking proper care of an Airstream.
This forum is like a happy silver cloud of information and knowledge.
Thanks for the input!
Shock replacement - all or one? RRRRRRV Shocks 4 06-21-2009 05:42 PM
Shock replacement dmadam Shocks 29 09-30-2008 08:55 PM
Replacement shock golddigger Shocks 11 10-12-2006 08:38 AM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 08:41 AM
Shock time Dbraw Shocks 5 03-08-2003 04:04 PM
