Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 06-21-2009, 02:04 PM   #1
Profile:  1979 25' Tradewind
Reno , Nevada
Shock replacement - all or one?
One of the shocks on my 1979 Tradewind is leaking fluid. Obviously I need to replace it but the other 3 shocks appear OK. Can I replace only the bad shock or do I need to replace them all to match? I understand I should only use the approved Gabriel shock.
Andrew
RRRRRRV is offline   Reply With Quote
Old 06-21-2009, 02:45 PM   #2
ASwifey's Avatar
Profile:  2007 25' International CCD FB
Bakersfield , California
You should at least change the other shock on that same axle. At least that's what we prefer to do in the shop I work at.
ASwifey is offline   Reply With Quote
Old 06-21-2009, 05:32 PM   #3
Commercial Vendor
Profile:  Corona , California
Andrew
You have the same mileage on all the shocks. The others should be right behind the first one. 30 years is a long time for shocks.
Replacing them all, will leave you with peace of mind for another long period of time.
While your at it, you should add a set of Centramatic balancers, and be done with that problem too.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-21-2009, 06:07 PM   #4
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
My 2 cents - change all of them. That's what I do on all my vehicles, change all four shocks/struts at the same time.
Old 06-21-2009, 06:42 PM   #5
Reno , Nevada
Thank you all very much for your quick responses. Turns out another one is a bit "wet" so I'll be replacing them all anyway.
Andrew
Shock replacement dmadam Shocks 29 09-30-2008 09:55 PM
TV Shock replacement recommendations FordTruck Tow Vehicles 15 12-31-2006 01:01 PM
Replacement shock golddigger Shocks 11 10-12-2006 09:38 AM
Suburban shock replacement Craig Tow Vehicles 3 11-28-2005 09:02 PM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 09:41 AM
