Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 07-10-2004, 11:08 PM   #1
Profile:  1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Shock replacement
I just had my wheel bearings repacked and brakes checked etc. I also took a look at the shocks. Just checked two and they were bad so assume the others are too. However the dealer gave me a price of $900. just for the labor. this seems little high to me. Any one have some experience with this?
David
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 07-11-2004, 01:13 AM   #2
wingfoot1's Avatar
Profile:  1987 29' Sovereign
Sparta , Tennessee
David
I just priced shocks at the airstream store at lansing. They were $38 each. That is high by my standards for a very simple shock. Your $900 is a ridiculous price. You have to jack unit up, remove tires to get to them, there will be some difficulty breaking the nuts and rubber bushings loose. Still a small job.
I wrote down the pertinent info: Gabriel shock, T40301SA, 610816.
Does anyone know how to cross reference these numbers in a auto parts house?
I plan to hit my local O'Reilly store etc.
wingfoot1 is offline   Reply With Quote
Old 07-11-2004, 01:44 AM   #3
LLB21's Avatar
Profile:
Hard to believe how someone could charge such a ridiculous amount. The shocks are about $38.00 each. They are available only from an Airstream dealer.
Labor couldn't be more than about one to two hours to do all four shocks including taking the tires off and on. I would find someone else to do the job. Lots of Brand X RV repair shops are afraid of Airstreams. They are afraid they will get into something they are not familiar with.
Louie
LLB21 is offline   Reply With Quote
Old 07-11-2004, 05:08 AM   #4
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Lightbulb Consider this...
David
David,
Perhaps this is his way of telling you, he doesn't want the job~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-11-2004, 06:58 AM   #5
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
Send a message via AIM to Sneakinup
If you supply the plane ticket for me to Vegas, I'll do it for $500 spending money!
If you are handy, it is not that difficult to do at all. Even if you dropped the axles to get the shocks on, it wouldn't take all that long.
What did they charge you to repack the wheel bearings?
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 07-11-2004, 07:54 AM   #6
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have two numbers for you the first is for the older AS and I think it is the one you need Monroe 33033. It fits a 1/2" stud top and bottom.
The next number is NAPA 555003 it fits a 5/8" stud at the top and a 1/2" stud at the bottom. We had to look through every shock in the book to find these two. The travel is correct as well as the bushing size. I bought the 33033 for mine but the bushings were the wrong size and trust me on this you can't put a 5/8" stud in a 1/2" hole.
You will have to use a prybar of somesort to pull the mounting arm away from the body just enough to allow the shock to be removed. This is "Standard Operating Procedure" for these shocks and hurts nothing. They are mild steel and bend easily. You can put them back in place or not depending on how you feel about it when you finish.
But do replace those worn shocks, I almost lost my rig on a straight level piece of interstate going about 50 mph. The potable water tank was only 1/2 filled and the water began to slosh from side to side. The 3 axel unit was almost out of control.
Hope this helps
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-11-2004, 06:24 PM   #7
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
David,
With the wheels removed to do the bearing pack, shocks could have been put on for very little effort. May be an extra 10 min per shock. Assuming 6 for a triple axle that adds up to 60 minutes total. If the $900 was for labor only,......hmmmmmm. Seems like there is some misunderstanding or I don;t understand the job.
I have replaced all 4 shocks on my vintage unit. And every vehicle I have ever had. Besides my Lincolns, shock replacement has been very easy. And even the Lincolns haven't been too bad. My '66 Overlander was easy.
>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 07-11-2004, 07:05 PM   #8
Las Vegas , Nevada
Thanks Guys for the info. They estimated 1 1/2 hours for each shock. Think I'll just slide under and figure it out. The bearing repack was $139. per axle.
Sneakinup-how bout a ticket and a couple hours at the penny slots and spit the winnings, not the losses. At least you might have fun in Sin City!
David
Old 07-12-2004, 09:23 AM   #9
Commercial Vendor
Profile:  Corona , California
Shock replacement
A "major" brake should be done every year or 10,000 miles, which ever is first.
A flat rate for a major brake for a 34 foot trailer is 3.5 hours. Replacing shocks at that time is flat rated at .2 to .3 hours, depending if the shock brackets must be bent or, if the shock bolts are rusted in place.
Contrary to opinion, axles do not have to be dropped in order to replace shocks.
Simply bend the brackets. It is also not necessary to straighten the brackets when done. Just leave them alone. It won't hurt a thing.
$900.00 for that job, means they don't want to do it, they lost big at the tables, or, they want to buy Hawaii, at your expense.
For the benefit of others, please post that companies name, so that others may not be exposed to that kind of ripoff.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-12-2004, 10:22 AM   #10
upallnight's Avatar
Profile:
I've just changed the shocks on my 30' Sovereign. I used NAPA 94005 which are gas charged. I feel the gas charged are best because they provide a constant downward thrust on the torsion arm of the axle. The NAPA catalog says they come with T1 mounts on the top and bottom which is 5/8" stud mounting. When I opened the first box I found they come with 5/8" top and 1/2" bottom. I simply drilled the rubber bushing on the bottom mount to 5/8" on my drill press. The whole job including modifying the lower mount on each shock took about 5 hours. The cost of the shocks was $25.00 each.
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Old 07-12-2004, 10:29 AM   #11
Las Vegas , Nevada
Thanks Andy, I went to them because Airstream gave me their name saying they have done work for them. I sent you an email before I went there asking if you knew anyone up here but you were in Hawii at the time.
The name of the place was Wheelers RV and the service writer was Nathan and the mechanic was Duke. By the way, did I get ripped off at $139. per axle for the bearing repack?
David
Old 07-12-2004, 11:41 AM   #12
Commercial Vendor
David.
$278.00 for two axles divided by 2.5 hours (the flat rate time) is a $111.20 labor rate. I think that is very excessive.
Did they replace the grease seals? If not, I would raise holy devil with them.
Reference gas shocks.
Gas shocks are "NOT" recommended by Airstream. If they were better than the horizontal shocks, they would have used them in production.
The point of it is, each shock can carry and absorb just so much of a "shock" or "G" force. The greater the weight of the vehicle, the greater the duty must be of the shock.
Therefore, since gas can go through an "oriface" easier than a liquid, they will not do an "equal" job as the horizontal Airstream shocks, rendering gas shocks not acceptable for use on an Airstream trailer, that has Henschen axles.
It's still amazing, where a choice is made to down grade something Airstream has used for years, sometimes for price, not even talking about the same performance, let alone better. Gas shocks have zero performance history on an Airstream trailer.
And then there is the issue of problems down the road, that are ignored, but usually, Airstream will get blamed for it.
A shock is not just a shock. There are different kinds for different reasons and useages.
It is wise not confuse or ignore the issue.
Gas shocks do not belong on any Airstream or Argosy trailers, period, that are equipped with Henschen axles.
For the leaf spring trailer owners, your on your own.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-12-2004, 12:05 PM   #13
Profile:  , Minnesota
Images: 59
David.
. . . . Gas shocks do not belong on any Airstream or Argosy trailers, period.
Would you make an exception for old leaf spring axles with vertically mounted shocks, or should I return them to the dealer?
Old 07-12-2004, 12:38 PM   #14
Commercial Vendor
Don.
My comments were directed to those owners that have Henschen axles only.
Sorry for the confusion. I will edit my original post.
Andy Rogozinski
Inland RV Center
Corona, CA
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 07:47 AM
replacement 66-67-68 window glass available rluhr Parts Archive 23 08-06-2004 02:05 PM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 07:15 PM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 09:41 AM
63 TW shock Moonshot Shocks 5 08-26-2002 10:24 AM
