Old 05-05-2019, 08:27 AM   #1
1994 34' Excella
Warren , Manitoba
Shock mount stud broken?
Working on a friends 1986 32' Excella, and pulled the wheels to repack the bearings and found 1 shock on each side missing. It looks like the previous owner decided to change the shocks, and twisted the threads off of the mount on the axle. I haven't tried to remove the remaing two, but have soaked them with penetrating oil prior to removal. Any idea where I can purchase the weld in stud type shock mount? Neighbour is a good welder and will weld in new ones if I can find them. We will drill out the old ones. Hopefully the mounts on the frame will not require replacement. Any and all ideas and thoughts on this appreciated. Thank you, Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
« Air Shocks???? | Top | - »
Shock mounting stud glrtex Repairing/Replacing Floor &/or Frame 6 10-22-2017 05:19 AM
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 02:03 PM
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 04:31 PM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 08:06 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
