Old 06-17-2010, 09:53 PM   #15
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by Inland RV Center, In View Post
The Airstream horizontal shock, extends from 9.5 inches to 14.5 inches.
However, it is too short to work with the "vertical shock" brackets.
It can be used, but you must cut the vertical bracket in half, overlap it and weld it back together, so that the stud to stud dimension does not exceed 14.5 inches, when that side of the trailer is jacked up.
But you must make sure that the rubber rods in the axle have not "solidified" which would restrict the wheel from dropping to it's maximum design.
Just to be clear... This thread is about a replacement shock for a leaf spring axle. No need to worry about rubber rods.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 06-26-2010, 02:21 PM   #16
1960 24' Tradewind
Janesville , Iowa
I just installed the 5752ST shocks. Turns out the measure 12 3/4" open and 8 1/2" closed. My old shocks measured 13" open and 8 5/8" closed. I think these will work great.
badger is offline   Reply With Quote
Old 07-01-2010, 02:18 PM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
In addition all pre-1967 Air Stream trailer had vertical shocks.
Original poster has a 1960 Tradewind.
>>>>>>>>>>>Action
Direct TV info needed Devoman Computers, Internet & Satellite 124 11-28-2008 10:17 AM
63 overlander commode info needed GKP4570 Sinks, Showers & Toilets 2 11-03-2008 09:44 AM
'68 Safari Info Needed gc24 1966 - 1968 Safari 3 09-08-2008 09:17 PM
Hello, MoHo info needed bobbrewer General Motorhome Topics 16 06-30-2007 04:52 PM
Gabriel shock number needed 63air Shocks 1 09-27-2005 10:23 AM
