Old 07-08-2011, 07:24 PM   #1
slk
Elk River , Minnesota
Shock info for 1996 Excella 25' tandom wheel
Can anyone tell me what shocks I need to get for this trailer. I am hoping I can go to a local auto parts house and get them.
Steve
slk is offline   Reply With Quote
Old 07-13-2011, 09:26 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The mounting position will dictate the shock.
Are they mounted more or less horizontal. (Parallel with the ground) If so an Airstream dealer is your only source.
Are they mounted more or less vertical. (pointing up and down) If so this application can be had at many different places.
My guess is you have the first type.
>>>>>>>>>>>>>>Action
Old 07-13-2011, 09:34 AM   #3
Steve
The shocks are "horizontal shocks".
They are specially made for Airstream, and cannot be purchased from anyone except an Airstream dealer.
Those special shocks are very reasonable in price.
A parts stocking Airstream dealer should be able to help you.
wheel bearing lube 1989 excella murphy Wheels, Hubs & Bearings 1 06-21-2011 07:25 AM
Upper shock mount sheared off 89 Excella pjg5842 Shocks 0 06-12-2011 08:17 AM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
