Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 09-26-2008, 06:09 PM   #1
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Michigan , The Great Lakes State
Shock clearance
Installing new shocks to a new axle and had to weld old lower shock mount to a new lower plate, it appears to be in the same place as the old one. However, when I went to install my new shocks the top part of the shock hit the backing plate of my brakes. I can move the top mount to give me clearance of about a 1/4", see attached picture, and would that be enough................thanks
ID:	68251   Click image for larger version
toastie is offline   Reply With Quote
Old 09-26-2008, 06:47 PM   #2
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Toastie - what if you flip the shock? Would that work?
Marc
Old 09-26-2008, 07:08 PM   #3
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
What is the clearance going to be with the tire mounted?
Richard
Charter Member Four Corners Unit
Old 09-26-2008, 07:12 PM   #4
toastie's Avatar
1955 22' Safari
Whoops, just put the tire on and have an hard interference, mount to tire.
Old 09-26-2008, 08:15 PM   #5
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
I have not seen a yellow colored shock for an Airstream. Is it the correct shock? Is the diameter too big? The six shocks I have installed were all black and did not look to be that large in diameter.
Just a thought.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 09-28-2008, 05:09 PM   #6
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Just a thought.
These are verticle shocks. So there are many choices that will fit the mounting. In 1967 A/S went to the horizontal shocks. A/S branded shocks is the only choice for that arrangement.
>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-26-2008, 08:58 PM   #7
Profile:  , Minnesota
Images: 59
You can flip the shocks to the inboard side of the frame. You need to weld the lower shock studs to the other side of the spring plate, and mount an upper stud on the inside of the frame. While you're doing that, weld another piece of channel fore and aft from the crossmembers on either side of the axle, to make a pocket for the shocks.
Then trim out the belly pan to clear the shocks.
Here's a picture of the frame pockets and the final arrangement, without the bellypan.
ID:	68255   Click image for larger version
Old 09-27-2008, 05:59 AM   #8
toastie's Avatar
1955 22' Safari
Does anybody know where I can get a bracket shown in the below picture, this would move the shock back and the upper shock mount away from the tire and would probably solve my problem.........thanks
Old 09-27-2008, 09:10 AM   #9
toastie's Avatar
1955 22' Safari
markdoane and 3Ms75Argosy
Took your advise and flip the shocks inboard and did a trail fit, and what a clean safe design, yes, it complicates the belly pan a little but very workable. Once all components are assembled using threadlocker will spot weld each fastener, yes, overkill, if I have to replace will cut out and replace with new....................thanks
ID:	68269   Click image for larger version
Old 09-27-2008, 01:32 PM   #10
1963 24' Tradewind
Good job! Just a thought. Check the wheelwell/ to tire clearance when the wheelwells go back on... your track may be just a bit smaller side / side than orginal. Do you have the old axle to compare the hub / hub distance? You might have to mount the wells inside just a bit more by the same difference in the two axles.
I'm jealous that you can fab up shock mounts so quickly!
Marc
Old 10-07-2008, 06:43 PM   #11
toastie's Avatar
1955 22' Safari
Marc
Great catch on the wheelwells, I did a trial fit and I'm about 1 1/4" away, is that enough?.............thanks
Old 10-07-2008, 08:34 PM   #12
1963 24' Tradewind
Hmmm, are you really that far away? It looks closer from this angle... and it could be an angle. If you can, try articulating the wheel upwards.. remember, the tire itself will flex a bit outwards with a bump, and then the wheel will go up. I "think" it might work.. but you might want to check. Or, you can just leave it as is, and then check the inside tires for any rub marks...
Some other ideas if you run up against bad clearance. Are your wheels at zero offset? If not, maybe new rims will get you a more positive offset away from the frame. Skinnier tires? If these are 225/75/15's, then a 7Rx15 will get more height and less width.
Ultimately, I think the supplied axle is a bit short. Do you still have the old one to compare hub / hub distance?
Marc
Old 10-08-2008, 05:26 AM   #13
toastie's Avatar
1955 22' Safari
Marc
The old axle is gone, what is zero offset............thanks
Old 10-08-2008, 10:09 AM   #14
1963 24' Tradewind
Offset refers to the distance the hub-face is mounted in relation to the rim.... so, if the hubface (the lugnut mounting surface) is directly in the middle of the rim from front to back, it's zero offset. If the hub surface is mounted more towards the rear of the rim (so that the wheel is pushed forward), I believe this is called Negative offset. Most rear wheel drive cars / trucks have this. Positive offset is when it's mounted more towards the front of the rim, making the wheel more inboard in relation to the hub (like most frontwheel drive cars..). I hope this makes sense. I believe the Tirerack.com has something about this in the wheels section.
Wheel Tech - Offset
More negative offset would make the rim go away from the wheel wells.
No problem about the old axle, I thought it might be illuminating to what's going on.
Marc
Airstream Clearance jcanavera The Vendor's Forum 10 09-15-2008 07:38 PM
clearance heights Silvertwinky On The Road... 6 06-07-2007 12:15 AM
Clearance rmcdon8848 Our Community 7 07-23-2004 10:34 AM
Wheel well clearance wardster Wheel Wells 5 08-13-2003 11:20 AM
63 TW shock Moonshot Shocks 5 08-26-2002 10:24 AM
