Old 03-27-2015, 02:49 PM   #1
Mantua , Ohio
Shock angle on early 1960s double axle
I have mixed thinking about how to mount the shocks on my new Dexter Shocks bought through Andy (2 weeks and 2 days I had them).
Vertical? Or on some angle?
Pros & cons?
Any thoughts would be GREAT!
Studioman is offline   Reply With Quote
Old 03-27-2015, 03:47 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The originals were vertical, and if you replace them in-kind, you will be able to use standard automotive shocks. You can get them at any auto parts store, and they cost significantly less than the horizontal shocks.
They will work the same whether horizontal or vertical.
Old 03-27-2015, 04:05 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
^^^^^^ Second that! ^^^^^^^
I had a '66 which was the last year for vertical shocks. Competition works better for my wallet.
>>>>>>>>>>>>>>Action
Old 03-28-2015, 05:34 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I kept my 66 with the vertical shock mounting. I did use Monroe automotive shocks purchased at my local NAPA. I think both the vertical and Airstream special horizontal shocks were in the $30 each range. I don't recall the shocks for my 86 being outrageous in cost from Inland.
I would be nervous designing an new shock mounting location on an old Airstream. My 66 has a separate piece of steel welded to the frame that extends into the wheel house and has a stud welded to it for the shock bolt. You can kinda see it in the photo below. Notice the stiffening rib formed into the shock mount. There is a ton of vibrational forces in a shock mount. The horizontal mounting design allowed the upper shock mount right on the frame rail.
I'm probably wrong, but I think the vertical shocks went away in 1969.
David
Name:	1406 Axle Rear Mounted 1.jpg
ID:	235055   Click image for larger version
Name:	1406 Axles Both Mounted.jpg
Late 1950s/early 1960s Small Drop Leaf Dining Table mello mike Cabinets, Counter Tops & Furnishings 33 12-02-2012 07:46 PM
To Shock or not to Shock jlovelady Shocks 35 11-16-2012 08:01 AM
Which is worse when towing, trailer angle UP or trailer angle DOWN? Streamer1 Towing, Tow Vehicles & Hitches 33 09-19-2006 08:43 AM
Starting angle of tag axle on 1984 345 MH? Honkity Hank General Motorhome Topics 5 08-02-2006 10:03 AM
Axle Angle tamis Axles 1 07-19-2005 05:30 PM
