Old 05-31-2011, 07:35 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Sheared shock mounts? Where to get replacements?
Anyone know where i can get new shock mounts for my 64? I tried everything before finally shearing off the nuts on my old shock mounts, and now i need to have someone weld on the new ones.
I was also told that I can use monroe shocks since I have a vertical placement for the shocks. Any thought on those?
Thanks!
robwok is offline   Reply With Quote
Old 05-31-2011, 07:44 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can use automotive shocks on your trailer with no problem. For the shock mount, you can remove the stud that broke and replace it with one that will fit in a hole you drill where the old mount was. The new shock mounting bolt is threaded for a nut to hold it in place. You can get them at most auto parts stores that supply "Help!" brand repair parts.
Old 05-31-2011, 09:30 AM   #3
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
ahh, so I would drill a hole instead of welding new mounts on? The part that broke was up in the wheel well of the trailer. Not sure I want to run through that many drill bits trying to get it just right. What about weldable mounts?
Old 05-31-2011, 10:40 AM   #4
Well Preserved
1993 21' Sovereign
You know you can bend that bracket down a bit so you can get a straight angle to drill?
shock bracket, shock mount, shocks
New axle sheared in two. Advice needed. letsgo Axles 41 12-18-2013 02:09 PM
'74 Excella Rebuild - The new chassis DanielB 1973-1974 Excella 500 359 11-04-2013 02:02 PM
'99 Airstream Cutter OEM Shock absorbers Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 11 08-25-2011 12:17 AM
Hensley zerks sheared off mojo Hitches, Couplers & Balls 10 05-23-2011 07:47 PM
