Old 08-16-2010, 07:20 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Retrofitting shocks on a '58
Alright guys, my '58 Overlander doesn't have shocks (not sure when shocks were standard). What's involved to install mounts and shocks to my standard axles? Note that I just had new axles installed two weeks ago.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-18-2010, 04:17 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Shocks came to be with the torsion axle. And that was some where around 1962 or 1963.
The leaf spring you have have better dampening qualities that the torsion axle so yuo may not have much benefit from having shocks installed.
If you still want to put shocks on your ride you will have to fabricate or have fabricated mounts to install shocks. You need to calculate the max travel up and down the axle will have to get the correct shock. You want a shock that will extend further than the greatest distance the axle will move away and compress a little further than the axle will move up toward the trailer frame.
The new axle manufacturer may have a kit to buy that can be attached to the axle and frame.
>>>>>Action
Action is online now   Reply With Quote
Old 08-18-2010, 07:45 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Action. Some good things to consider. I'll put some more thought and research into this.
1958 Overlander
4CU 1st VP
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
Retrofitting Bunks/ Hammocks Lumatic General Interior Topics 3 06-05-2007 12:37 PM
Retrofitting Roof A/C 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2003 04:54 PM
shocks davespann Axles 1 02-28-2003 05:44 PM
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 18 09-20-2002 10:24 AM
