Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 05-23-2006, 03:32 PM   #1
caadoptees's Avatar
Profile:  1992 25' Excella
Visalia , California
Images: 16
Send a message via AIM to caadoptees Send a message via MSN to caadoptees Send a message via Yahoo to caadoptees
Replacing shocks - what to look out for?
I have new shocks coming (along with the window rock guards). I have no idea when the last time these were replaced. At most 14 years ago! They look like they need so I will do it.
I sure don't want to twist off a bolt or anything like that. Should I load them up with a 'liquid wrench' type of solvent first? A friend mentioned to use a torque wrench, not so much for putting them on but taking them off so you don't use too much oomph and bust it.
Best practices please?
Roger & Roxie Smith (WBCCI#27380 - Air#178)
Visalia, CA (between Fresno & Bakersfield)
1992 25' Excella - Nuestra casa rodante
2003 F-250 6.0 Turbo Diesel Crew Cab
http://www.casarodante.org
caadoptees is offline   Reply With Quote
Old 05-23-2006, 10:14 PM   #2
Profile:  1960 24' Tradewind
santa barbara , California
Hello caadoptees,
My favorite rust penetrent that works remarkably well ,is called PB Blaster .I get it from my local CarQuest auto parts store.Napa might have it too.I use it mostly for exhaust manifold studs and nuts where the exhaust pipe attaches
at the manifold ,almost daily in my auto repair shop .Spray your shock nuts well and go have a sandwich or ? come back and give them a turn.I spray it on as Im turning the nut if needed.Patience is key ,let the blaster work a bit
and they should come off.WD40 is better for lubricating the nuts upon reassembly .There is of course liquid wrench ,but PB Blaster is exceptional
on rusted fasteners.DONT put a torque wrench on them to remove ,you want to be able to "feel" the nut as it works loose,is it coming off too tight ,more penetrent ? etc.
Good luck there
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 05-24-2006, 07:31 AM   #3
Profile:  1977 31' Sovereign
McHenry , Illinois
After the oil has set a while a propane torch will make it pentrate more. Let it cool down and douse it again. wait and then use an air impact wrench set on low pressure work the fastener loose. You should use low setting first to get some movement to get the oil to seep in more. It takes time but you do not want to break the bolts. Impact is better than brute force. Torque wrench is better used to make sure you put things back together with proper pressures.
Old 05-24-2006, 09:00 AM   #4
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
Kroil is great stuff
Hi Roger & Roxie:
My favortie penetrant for rusty parts is Kroil/AeroKroil made by by Kano Labs and purchased direct from the factory. Details can be found on their web site:
http://www.kanolabs.com/
I use enough to buy it by the case of 12/10 oz. cans every few years. You may wish to purchase just a few cans to try. I let it soak in for 5 minutes or so before wrenching, and apply it again if there is no movement at first. Its wonderful, real stuff.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 05-24-2006, 10:23 AM   #5
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Amazingly, my bolts required nothing at all to loosen, and the last place my Airstream was registered was Minnesota! I'd have figured with all the de-icing they have to do up that way they'd have been hard to remove, but not so. Crescent wrench was all I needed.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 05-24-2006, 04:15 PM   #6
Supposititious Blue
65GT's Avatar
Profile:  Charlotte , North Carolina
Images: 26
Roger -- JUST IN CASE...
I don't expect you'll have any issues out on the left coast with a '92, but just in case you find yourself having to exert a bit of force even after a petrol soak you're better off stopping and getting yourself a nut splitter.
Trust me -- I snapped off TWO out of four last year. My unit's a '65 and I'm pretty sure it had the original shocks on it so I wasn't only dealing with rust, but iron oxide deposits on the threads that a wire brush didn't adequately remove.
I don't expect you'll have these problems but if rusty looks deformed rusty in any way you're probably better off cutting the nut in two and starting fresh with at least a new nut (and lube).
Nut Splitter? You could buy one but I'll bet your local tool rental store has one you could have for $10 for a morning on the spot.
http://www.sjdiscounttools.com/ast9449.html
By the way -- how'd you bridge that gap between PA and KY?
__
6000+ Airsteam families having fun!
1000+ Airstream Events including 500+ Rallies in 2009!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Old 05-24-2006, 04:22 PM   #7
caadoptees's Avatar
Images: 16
__
Well, the map is a bit of a fudge as far as an Airstream goes. It shows where I have actually been through my years. The NorthEast area was via Airplane. I don't know what map to use. Where I have been (the one there now), where I have been in an Airstream (maybe about 10 states off of the current one) or where I have been in an Airstream with MY family (western states)?
Old 05-24-2006, 09:48 PM   #8
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
I don't know if you can find it out there, but I use Howe's oil for all my rusty fastener removal adventures. Also, if you don't have a handy impact gun, you could get the same effect in a crude fashion from a box-end wrench and a hammer. Put the box end on the shock nut, and tap the other end with the hammer until the nut starts moving.
(No Longer at Inland RV)
Old 05-27-2006, 05:48 PM   #9
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
And the answer could have been Canada.
>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 06-05-2006, 10:48 PM   #10
caadoptees's Avatar
Images: 16
I got the trailer out on the street now and took off one wheel to see what I had to work with. The shock looked pretty easy. I put on the PB fluid and waited about 3 hours. I put on the socket and tried the nut. It turned very smoothly and came off with out incident. That was the nut on the bolt on the chassis. The other nut was more interesting since it faces the trailer, this is the one that is on the axle. That is why it is good to have tools. I used the wrench in the picture and the nut came off there also. When I removed the old shock I noticed that the bushings were in two pieces. A bit odd but I found out why when I tried to put on the shock on the bolt on the axle. There was not enough room to get the shock on with the bushing attached. Now I know why they are split, so I split mine too! It fit perfectly and tighten up just fine. So one is down. I have to wait for the rest until I get a new tire on this wheel. But thanks to all that gave words of encouragement and advice.
On the photos, the first is the new shock installed. Second is the old shock with the split bushings.
ID:	22057   Click image for larger version
Old 06-06-2006, 03:46 AM   #11
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
When I removed the old shock [from the stud on the axle] I noticed that the bushings were in two pieces. A bit odd but I found out why when I tried to put on the shock on the bolt on the axle. There was not enough room to get the shock on with the bushing attached. Now I know why they are split, so I split mine too! It fit perfectly ...
INCREDIBLE! If I understand you correctly, the split bushing allowed you to remove the shock from the axle stud without de-mounting the axle or bending the shock flange? If true, I am stunned-- --there are pages and pages of posts about how crappy it is that you can't remove the shock without major axle work or bending something.
Even Inland Andy, who knows all, personally demonstrated to me that the mounting flange had to be bent away from the frame in order to get enough clearance at the stud tip!
Karma to you... make that big karma.
I'm looking again at your photo and it looks exactly like my installation on all three Airstreams. Is it possible that in the '90s there is just a little more stud-to-frame room than on the '70s models? (Holding my breath here...)
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Old 06-06-2006, 07:36 AM   #12
Well-Preserved
Nope, the shock bushings were changed at some point to save money on manufacturing. 99+% of the time, this is not an issue, but if you have that 1% where it makes a difference for mounting, it makes removal a problem. I am aware of no reason you can't split the bushings, like the old ones were, so you don't have to bend the mounts. It can be rather time-consuming, however.
Old 06-06-2006, 08:37 AM   #13
bake315's Avatar
Elgin , Texas
Images: 161
I split my bushings, too. Used a PVC pipe cutter. Easy easy lemon squeezy!
And even with splitting them, there was still a little bit of a need for some hot crowbar action.
Cheers, Dave
"Finish."
AIR #4188
Old 06-06-2006, 10:54 AM   #14
caadoptees's Avatar
Images: 16
I will measure the distance on the next set I do. However with the full bushing in the shock I probably could have pryed it in there somehow. After splitting, you put in half a bushing, the shock and then the other half. I didn't have any problems getting just the shock on there. Maybe I got lucky for once!
What shocks? Silver Annie Shocks 6 11-04-2002 12:14 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 09:16 PM
New Shocks Melissa Hamilton Shocks 13 07-04-2002 08:30 PM
installation of shocks TCP4 Shocks 1 05-02-2002 05:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 11:13 AM
