Old 08-03-2006, 06:25 AM   #15
1971 27' Overlander
Richmond , Virginia
Thanks!
Hi Everyone,
Thanks for the advice and discussion about the shock situation on my Overlander. I will definately be replacing the shocks even though I have noticed the natural dampening of my axle setup. I am pulling this trailer with what I consider to be a small truck (Chevy 1500 1/2 ton - 4.3 V6), and I want the trailer to be in the best pulling shape as possible to reduce the amount of strain on the truck. I recently mounted new tires and restored my brakes and bearings. The trailer pulled extremely well and the brakes worked liked a charm (I attribute much of the flawless brake performannce to the Prodigy brake controller that I installed).
I feel considerably more educated after visiting the forums, so thank you very much. I hope to see you guys on the road!
Everett
ecomstock is offline   Reply With Quote
Old 08-03-2006, 08:46 AM   #16
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Talk about being on the edge. Depending on year and axle ratio this truck is rated to tow 5000 #'s. Your trailer dry is 4500 #'s. Add gear, propane any spare equipment, not to mention water and or waste you are at limit or over. The truck would also have to have the following to make the 5000 # rating:
to be 2 wheel drive with automatic
3.42 axle ratio or 3.73
Z82 tow package
oil cooler and tranny cooler
and a weight dist hitch
The shocks will not make much difference on that trailer with 35 year old axles.
>>>>>>>>>>>>>>>>>>>>>>Action
Old 08-03-2006, 09:01 AM   #17
Frank S
peoria , Illinois
Hi ecomstock--I agree with Action, and think you may be over the edge. I have a 1973 27' Overlander which has a loaded weight of 6200# on the A/S axles. The axles are at a slightly negative angle, so axle replaqcement is next for me.--Frank S
Frank S is offline   Reply With Quote
Old 08-17-2006, 11:03 AM   #18
Dan@LED4RV's Avatar
Denton , North Carolina
I would have to say this is a good thread. I have found that using a crow bar on the arm that connects to the inside of the Dura Torque to be able to get the shock on veries from job to job. I stopped doing it that way as the age of the rubber effects this. Or, so was my conclusion. And it may be changing the axles is needed if they are real old and the rubber is hard.
For the most part, having the trailer up on jack stands and being under it with a crow bar never appealed to me. That is why I like cutting the rubber grommet or bushing.
http://s114.photobucket.com/albums/n276/fixer58/
Once you cut it in half, you put half the bushing on, then the shock, then the other half the bushing. After that it is the washer, a little lock-tight, and then the nut.
Nice layout Zeppelinium
http://www.airforums.com/forum...1-post131.html
For the most part a agree with everything Andy has said. I just like cutting the rubber bushing.
Dan@LED4RV is offline   Reply With Quote
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
installation of shocks TCP4 Shocks 1 05-02-2002 04:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
